Quote from: Walnut Beast on December 20, 2022, 06:25:27 AMYes. Get efficient cutting without the cord with the XSH10Z. It makes up to 110 cross cuts in 3x12 oak board using two fully-charged 5.0Ah batteries. The electronically-controlled brushless motor delivers a full 4,500 RPM for efficient cutting, with Automatic Speed Change™ technology to adjust the cutting speed and torque under load for optimum performance. WBYou have this one? How long have you had it?A review?
I never use the stock blade, it’s good for crosscut but not for ripping. I use the 16 tooth Panther ripping blade with much better 2” deep rips and easily resharpend. It will crosscut slabs fine, also. I’ve also used a couple other ripping blades, but keep going back to the Panther. I also keep a couple screwdrivers stuck into the foam board. Whenever the wood starts to bind the saw, I’ll jam a screwdriver in the kerf to jack it open. That’s works really well.
Actually the 40V has better sustained power even though less RPM's and the battery comes with 2.5 ampH, but a 5 ampH is an option. It actually cuts faster in the end. Those two batteries on the 36V overhang a lot, interfering with some cuts, making it wider and heavier and the top 18V battery is a bit of a knuckle banger.
Festool is great but no 75s now. And been that way for a long time. Toolnut Recommends this unit in place of the 75 and it’s cordless and cuts over three inches and will work with the Festool track.The XSH10Z is compatible with Makita Guide Rails (sold separately) for accurate ripping. With a large cutting capacity of 3-3/8” at 90◦, the XSH10Z can conquer demanding applications such as ripping and cross cutting larger beams, boards and forms.
Started by beenthere on The Outdoor Board
Started by xlogger on Drying and Processing
Started by cleargrain on Sawmills and Milling
Started by maineshops on General Woodworking
