Author Topic: 440b steering cylinder problem  (Read 512 times)
Offline Solo33
  • Green horn
« on: August 20, 2021, 04:50:13 PM »
Had my 440b right side steering cylinder packing go, took it john deere for a new kit and it was leaking again but due to the head or nut not being completely tight, so they replaced it again. Just put it back in, let it idle to check for leaks. Went to make some turns and then this happened. Not sure if I should have bled the system or if the cylinder was just worn out. Any thoughts?
I know I was born and I know I will die, the in between is mine, I am mine
Online mike_belben
  • Pulp Friction
Re: 440b steering cylinder problem
« Reply #1 on: August 20, 2021, 09:01:25 PM »
If im seeing it right thats a floating gland nut that takes a snapring.. No?
First guess snapring didnt seat.
Isaiah 63:10
Offline Oliver05262
« Reply #2 on: August 20, 2021, 09:58:56 PM »
Web parts diagram doesnt show any snap ring. The pictures look to me that the gland threads into the cylinder barrel, and the threaded inner end broke off the outer exposed part of the gland. Possibly it was cracked and that was causing your leak.
If you can walk the threaded remains out of the barrel, should not be too bad of a fix.
Please post some pictures of what you find.
"You can't do wrong by doing good"
It's OK to cry.
I never did say goodby to my invisible friend.
Online mike_belben
  • Pulp Friction
« Reply #3 on: August 20, 2021, 10:01:19 PM »
boy i hope its not that, but on the laptop it kinda looks that way.
Isaiah 63:10
Offline Oliver05262
« Reply #4 on: August 20, 2021, 10:16:41 PM »
  If it is what I first thought, it might come out with a combination of pecking at it with a small center punch (you know the word I want to use there)and someone slowly turning the rod counterclockwise. Ya gotta have hope!
 Or maybe the threads stripped off. How worn are the center pins? Does this machine have turn stops that are missing/worn? Has that gland become the turn stop?
It's OK to cry.
Offline Solo33
  • Green horn
« Reply #5 on: August 22, 2021, 05:18:28 PM »
The stops are in place. It did bind the first time I put it back on trying to line up to put the pins in. Possibly could have made it weak then, leading to it breaking like it did. I'll know more tomorrow when I take it back off. Hopefully it's repairable or else I'm looking for a good used cylinder.
Online mike_belben
  • Pulp Friction
« Reply #6 on: August 22, 2021, 09:12:21 PM »
fingers crossed for ya.
Isaiah 63:10
steering cylinder leaking
Started by huntdibbs on Forestry and Logging
Last post February 02, 2014, 03:12:12 PM
by John Woodworth
Access to Front Pin on Steering Cylinder TJ230E 1978
Started by Mountain_d on Forestry and Logging
Last post September 27, 2017, 06:23:41 PM
by Mountain_d
Jd 440 Steering problem
Started by mackaylake on Forestry and Logging
Last post April 09, 2014, 09:58:52 PM
by Old Iron nut
Steering problem
Started by loggerman1959 on Forestry and Logging
Last post October 25, 2016, 08:40:59 PM
by loggerman1959
