Author Topic: Don't Shout!  (Read 3039 times)
Offline Jeff
  • Fearless Leader
  • Oh la di oh la da
    • Behind the  Forestry Forum YouTube channel
Don't Shout!
« on: December 28, 2008, 05:43:36 PM »
TESTINg typing with my cap locks on...
Offline SwampDonkey
  • Large Tooth
Re: Don't Shout!
« Reply #1 on: December 28, 2008, 07:15:32 PM »
Yeah, earlier I noticed a popup when I started a new sentence with a capital. Too many peops on CAPS mode?
“No amount of belief makes something a fact.” James Randi
Offline Jeff
  • Fearless Leader
  • Oh la di oh la da
Re: Don't Shout!
« Reply #2 on: December 28, 2008, 07:24:05 PM »
Did you start with a capital using the shift key or with cap lock?  You shouldn't get an alert using shift.
Offline beenthere
Re: Don't Shout!
« Reply #3 on: December 28, 2008, 08:26:38 PM »
GOING TO TRY THIS (CAPS LOCK ON)
No warning....??
But sounds like a good plan.
Re: Don't Shout!
« Reply #4 on: December 28, 2008, 08:47:13 PM »
IT SURE TELLS ME when I do it.  It doesn't always show up on the same number of characters.  I don't know he measures it, but it works.  If you click the OK on the popup, it lets you type in caps anyway.
It worked for me with caps lock and when I pressed the shift key.... both ways
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
Re: Don't Shout!
« Reply #5 on: December 28, 2008, 08:48:41 PM »
Hey, that's cool. 8) Only does it with the Caps lock for me. 8)
Offline sawguy21
Re: Don't Shout!
« Reply #6 on: December 28, 2008, 08:56:49 PM »
Same here.
Offline Dan_Shade
  • I don't want to edit my profile!
    • Shade Custom Sawing
Re: Don't Shout!
« Reply #7 on: December 28, 2008, 09:32:41 PM »
IT DID IT WITH THE SHIFT KEY THE FIRST TIME I TRIED IT!
lots of dull bands and chains
Offline Dan_Shade
Re: Don't Shout!
« Reply #8 on: December 28, 2008, 09:33:45 PM »
the second time I tried it, it didn't fuss.
Jeff, can you fix up one of these sorts of things for use on my mother?
Offline Warbird
Re: Don't Shout!
« Reply #9 on: December 28, 2008, 10:58:40 PM »
Interesting.  How is this being done?
Offline Jeff
  • Fearless Leader
  • Oh la di oh la da
Re: Don't Shout!
« Reply #10 on: December 28, 2008, 11:57:00 PM »
With Javascript you can use what are called event handlers to form an action. You can set events for certain key strokes. For Example the textarea that you type your posts into have several things taking place. The code looks as below.
<textarea class="editor" name="message" rows="12" cols="60" onselect="storeCaret(this);" onclick="storeCaret(this);" onkeyup="storeCaret(this);" onkeypress="captureKeys(event, 'It appears that you may be inadvertently typing with ALL CAPS.\n\nPlease check your cap lock key.\n\nWriting in all caps on the Forestry Forum is considered SHOUTING');" onchange="storeCaret(this);" tabindex="2"></textarea>
The new part that is taking care of cap lock warning is the onkeypress event plus an associated javascript. There isnt a way to know if you have the cap lock on, but once you type, using the javascript, the browser sees the input characters as ASCII code and then know what to do if it sees certain strings. If it identifies the ASCII code range that indicates uppercase letters formed using the cap lock, which is different then the code for uppercase letters formed by the shift button, the handler part of the script returns the alert.
The script looks like this:
Code: [Select]
var count = 0;
var shown = false;
function captureKeys (e, errorMsg) {
    var ev = e ? e : window.event;
    if (!ev) {
      return;
    var targ = ev.target ? ev.target : ev.srcElement;
    // get key pressed
    var which = -1;
    if (ev.which) {
      which = ev.which;
    } else if (ev.keyCode) {
      which = ev.keyCode;
    if (which >= 65 && which <=  90) {
count++;
if (count == 6 && shown == false){
// uppercase
alert(errorMsg);
shown = true;
} else {
count = 0;
return;
Offline Jeff
  • Fearless Leader
  • Oh la di oh la da
Re: Don't Shout!
« Reply #11 on: December 29, 2008, 12:01:59 AM »
The other events you see within that textarea code are used for inserting things like the smilies by clicking on them, the BBC tags, and inserting the code from the gallery on click, and things of that nature.
Offline pigman
Re: Don't Shout!
« Reply #12 on: December 29, 2008, 12:03:28 AM »
NOW YOU HAVE ME CONFUSed with all that Greek. I took the caps lock off when it warned me.
Offline Jeff
  • Fearless Leader
  • Oh la di oh la da
Re: Don't Shout!
« Reply #13 on: December 29, 2008, 12:04:15 AM »
One more thing,  YOUR BROWSER MAY VARY!  :D  These code snippets can be very browser dependent and many times what works in one doesnt work in another. Or worse.
Offline Warbird
Re: Don't Shout!
« Reply #14 on: December 29, 2008, 12:37:56 AM »
That is pretty cool.  You could do some fairly interesting things with that.
Offline isawlogs
  • A smile is contagious ... Start an epidemic
Re: Don't Shout!
« Reply #15 on: January 21, 2009, 10:25:06 PM »
  SO IT MIGHT WORK FOR SOME BUT NOT SO FOR OTHERS , I GUESS I AM ONE OF THOSE THAT IT DONT WORK FOR  :-\ :'(
  I got a question for you computer gurru ....  Ya know how the pop up for an instant message is supose to pop up when ya get a message ... and open in another window when ya click it ... why dont it do that for me pop up in an another window ... it pops up  TO TELL ME i GOT A MESSAGE ...
   Marvel , challenged at times
Well actually often , but who is keeping track .  :-\
   Marcel
Shout out to anyone near Knox, Tn!
Started by Tnwoodsman on Sawmills and Milling
Last post November 10, 2015, 01:52:24 AM
by 5quarter
Shout out to female tailers
Started by scully on Sawmills and Milling
Last post October 05, 2016, 10:46:30 PM
by Okrafarmer
Shout-out to New Mexico Tree farmers...
Started by chain on General Board
Last post December 29, 2010, 08:15:26 PM
by chain
Shout out to Marty Parsons and Wood-Mizer PA
Started by DR_Buck on Sawmills and Milling
Last post December 18, 2017, 03:05:32 PM
by Wudman
