Author Topic: Need advice felling trees  (Read 4268 times)
Offline park ranger
Re: Need advice felling trees
« Reply #20 on: May 30, 2014, 01:52:07 AM »
Yesterday I used my grip hoist to pull over a few trees next to a friends cabin.  It uses 3/8" cable and the cable goes thru it instead of piling up in it. I hook on as high on the tree as I can and as soon as I can I put a couple of wedges in the back cut and then when I cut up to the hinge I pull it down.  No streching of rope to wounder about.  I'd google grip hoist.  Eric
Offline 101mph
« Reply #21 on: May 30, 2014, 12:07:53 PM »
That grip hoist looks like an excellent tool.
Pricey...but looks like it works great.
Offline ohwc
    • Old Hat Wood Co.
« Reply #22 on: May 30, 2014, 12:17:29 PM »
Talk to the USFS office or DNR office. Some of the fallers there may do some side work and can fell them for you.
Offline mad murdock
« Reply #23 on: May 30, 2014, 01:03:13 PM »
another great tool for smallish trees( say <16"DBH), is the "Timberwinch" that Logosol sells, check out their video of it in use,  It is a powerful tool.  Northman has some very good advice, if you at all are uncomfortable about the outcome of felling a tree, don't make any cuts and walk away, or get a pro to do the trouble ones for you.  It will be way cheaper than a hospital bill or funeral.
Offline CTYank
  • Ain't he cute?
« Reply #24 on: June 01, 2014, 11:03:02 PM »
Chainsaws are plenty dangerous, avg injury- 125 stitches. On the other hand, trees and their pieces are more inclined to kill you. Always show respect.
For basic felling tools, I'd suggest a few each of 5" and 8" wedges. Besides felling, they come in very handy for bucking. Then a 1/2 or 1-ton cable winch, chains to grab the tree stem and the anchor, and nylon tow straps for inexpensive high-tensile "line". More than one line holding tree in a few different directions help to pull a tree or just restrain motion. Think of pulling on one with winch, while the other restrains it to move in a circle. Lines, chains and tow-straps are way cheaper than hospital visits. Same principle applies to PPE: chaps, combo helmet, 1st-aid kit, etc. Look up often.
If pulling on a winch during the actual felling would make you a target, hook another line at right angles to the winched line, near its midpoint. Tug on that line, while well clear of the impact area. Beats heck out of being planted.
'72 blue Homelite 150
Echo 315, SRM-200DA
Poulan 2400, PP5020, PP4218
RedMax GZ4000, "Mac" 35 cc, Dolmar PS-6100
Husqy 576XP-AT
Tanaka 260 PF Polesaw, TBC-270PFD, ECS-3351B
Mix of mauls
Morso 7110
Offline justallan1
  • living and learning
« Reply #25 on: June 01, 2014, 11:32:52 PM »
Just a thought, but who is responsible for the power lines there? In a lot of areas the power company comes out and keeps that rite of way cleared. Where I'm at they do any going through the property, but not the ones going to the house. If they clear them off the lines for you I'd offer the workers some cash to work late and get the ones near the house also.
Allan
Offline 101mph
« Reply #26 on: June 02, 2014, 08:38:25 AM »
Again thanks a lot guys!
Lot's a great info on tools, technique and advice. I will look into all of it.
As far as the power company is concerned, they did come down our road last year to trim away branches and small limbs near the power lines to keep enough clearance. I wasn't there but was told they used some sort of large machine to go down the road to do all of the cutting. I believe that's about all they would do.  I'm not sure if they were actually equipped to fell any large trees.
Offline Jeff
  • Fearless Leader
  • Oh la di oh la da
    • Behind the  Forestry Forum YouTube channel
« Reply #27 on: June 05, 2014, 01:14:27 PM »
I would go up to the local pub and get to know the bar tender, he'll know the best man to get to come and help you out.
This may be the worst advice I  have ever seen given on this forum. I should delete it, but I'd rather make an example out of it. I hope it was made in jest and not as a serious statement.
Offline Offthebeatenpath
    • OBP Trailworks, LLC
« Reply #28 on: June 06, 2014, 01:43:04 PM »
101mph- + 1 for me on the griphoist.  It's a fantastic tool.
Park Ranger (Eric)- I'm assuming you have a 2000 pound capacity griphoist (T-508 or TU-17).  That machine takes a 5/16" wire rope, not ⅜".  If you are using a ⅜, you could have some issues coming very soon.  I'm not ragging on you, just making sure you stay as safe as possible
Jed
1985 JD 440D, ASV tracked skid steer w/ winch, Fecon grapple, & various attachments, Hitachi CG-30 tracked dump truck, CanyCom S25 crawler carrier, Volvo EC35C mini-ex, Kubota 018-4 mini-ex, Cormidi 100 self loading tracked dumper, various other little trail building machines and tools...
Offline Black_Bear
  • UMaine Black Bears
« Reply #29 on: June 06, 2014, 02:58:17 PM »
I'm not trying to argue the point, but in the area I grew up in, it was, and still is, a common thing to get jobs or make contacts via a local bartender or other patron of the bar. A person obviously can seek advice and information from almost endless sources today, but I can relate to the above statement.
A lot of special situations involving tree cutting, whether in a forested environment or in the neighborhood, should be done by professionals with insurance and special knowledge. You can't spend your money if your dead.
Offline beenthere
« Reply #30 on: June 06, 2014, 03:55:10 PM »
All kinds of the locals frequent our local pubs for lunch and some even for a beer. ;)
Burlkraft and I used to go to "da Rox" for lunch, and there was no end to the local stories and information about what was going on locally being tossed around. Only needed to ask if wanting to know who died, who logged, who had a baby, or who was/got married.
The poor bartender has to listen to all those stories and hopefully can sort out the good information from the "not-so-good".
"Tom" at da Rox wouldn't say much, but he did listen a lot. I'm betting he rolled his eyes  ::) a bit when we were there.  ;D
Maybe Jeff was thinking of some other kind of local bar tender.
Offline Jeff
  • Fearless Leader
  • Oh la di oh la da
« Reply #31 on: June 06, 2014, 04:02:36 PM »
Yea, alcohol bar stools and the best advice usually go hand and hand. Ya'll get your information anywhere you want.  The loggers I knew that hang out in the bars boasting greatness aint the ones I'd want on my job, especially on the word of the guy serving the booze.
Offline beenthere
« Reply #32 on: June 06, 2014, 04:14:57 PM »
 That puzzles me, but will move on.
Offline Jeff
  • Fearless Leader
  • Oh la di oh la da
« Reply #33 on: June 06, 2014, 04:48:27 PM »
How many drunks have you encountered on the job?  I've had to endure several. Because the Boss would hire guys recommended to him by his drunken buddies at the bar.  "Oh, he's a great worker"  And then you see them at lunch the first week taking the back way to the mill so they can slam the rest of their Jumbo, or wonder why they are chomping on a big wad of gum at 5am in the morning.
Offline John Mc
« Reply #34 on: June 06, 2014, 04:54:06 PM »
Logging is dangerous enough without having to deal with a drunk endangering himself and everyone else around him.
Offline Ed_K
« Reply #35 on: June 06, 2014, 07:45:51 PM »
 Ah, the life and times gone bye of the river driver  ;D .
Ed K
Offline LorenB
« Reply #36 on: July 03, 2014, 12:57:58 AM »
101 mph,
A lot of the advice here is from folks who know this business much better than I do, but one issue hasn't been mentioned strongly enough:  Each one of those trees weighs more than your pickup truck.
Okay, I don't really know how big your trees are, so they may not weigh that much, but they probably weigh more than you realize.  Do the math on a 30" DBH tree that's 50' tall and you'll find that it can easily weigh 5000 pounds at green moisture content, and that's just the trunk.  Add in the weight of the branches and you get a number that should engender respect.
I have studied trees with the thought to using a rope or two to bring them down where I want them and then realized that it's quite possible for the falling tree to break the rope.  If you use a stronger rope and tie it to your truck's bumper you could easily remove the bumper from your truck.
Add in the potential costs involved in cottage repairs, not to mention hospital bills, and a professional looks better and better.  Felling trees isn't really something you can learn by reading about it, although knowledge of physics will help a lot.
I don't want to discourage you from tackling anything you are capable of doing safely, but remember that logging is one of the most hazardous jobs in America.  If you are neither trained nor supervised you should consider handing this job over to someone who is.
Disclaimer: I am not a professional logger.  I run a sawmill and will cut my own trees but will not cut trees for customers.  There are too many things that can go wrong.
-- Loren
Loren
Baker 3667D portable sawmill, Cook's edger, Logrite arches & peaveys.  Husky 272XP chainsaw & two Echos.
Offline thenorthman
  • Now we're logging
« Reply #37 on: July 03, 2014, 08:41:48 AM »
Not to rain on your parade to hard there Loren,
Most of the weight of a tree is centered over the stump, unless its a hard leaner, even then the leverage gained by getting a rope as high up as possible counter acts enough weight to make it possible for the average skinny dude to pull a tree over by hand.
Having said that I am a professional, I do this all the time.  As long as your not trying to pull over a super hard leaner and you make proper felling cuts, a pick up truck works pretty good for pulling trees over, I've never lost a bumper, and never broke a rope while pulling trees over.  I have broke a few when they get in a bind on the way down however.
Also if you use a decent sized rope, the breaking strength is higher then your truck weights.
well that didn't work
Offline LorenB
« Reply #38 on: July 03, 2014, 09:41:24 AM »
thenorthman,
Yeah, I know what you're saying, and I agree with you.  In fact your advice that you posted back in reply #5 was excellent.  Back then you advised 101mph to get 5/8 to 3/4 inch braided nylon line.  That's stronger rope than most people would use.
As I said, an understanding of physics helps with felling trees, and the physics of leverage work in the feller's favor.  The point I was trying to make to 101mph was that he should respect the huge forces involved in cutting down a tree.  Logging is dangerous work and you really do need to know what you're doing or someone could get hurt.  That's something else you told him in your earlier post.
You gave him good advice; I was just trying to add another caution.
-- Loren
Loren
The old way of felling trees (with a felling axe)
Started by nebruks on Forestry and Logging
Last post February 25, 2012, 11:05:39 AM
by Jeff
Felling trees during TSI
Started by Good Feller on Ask The Forester
Last post December 22, 2008, 10:44:30 AM
by Ron Scott
Felling Trees Without a Saw?
Started by Philbert on Forestry and Logging
Last post January 25, 2015, 07:01:59 PM
by Lorenzo
Ok I have been felling trees,
Started by derhntr on Forestry and Logging
Last post April 30, 2006, 09:41:43 PM
by derhntr
