Author Topic: 1967 Tree Farmer skidder  (Read 1925 times)
Offline 1961david
« on: November 02, 2014, 11:51:53 AM »
The transfer case on this model has two plugs on the rear of the case. Which one is the proper one to maintain the level of gear oil at?
Offline SliverPicker
Re: 1967 Tree Farmer skidder
« Reply #1 on: November 02, 2014, 12:36:59 PM »
I don't imagine you could go wrong if you used the upper plug as the gauge.
Yooper by trade.
Offline 1961david
« Reply #2 on: November 02, 2014, 12:45:43 PM »
Thats what I am doing, using the top plug. It just seems weird that they have two plugs one 2" above the other?
Offline North River Energy
« Reply #3 on: November 02, 2014, 01:04:13 PM »
My older skid steer has a similar arrangement on the chain case, with two small upper plugs, and a larger drain plug down low.
The top plug is the 'daily check' plug, the middle plug is the one you pull when nothing is present at the top plug.
Offline thecfarm
« Reply #4 on: November 02, 2014, 04:25:11 PM »
1961david,welcome to the forum.
Offline John Woodworth
« Reply #5 on: November 02, 2014, 06:03:30 PM »
The bottom plug nips ment to be the fill and the top a vent while filling, it won't hurt anything to fill to the top but fill through the bottom till it gets to that level then top it off, it's faster.
Two Garret 21 skidders, Garret 10 skidder, 580 Case Backhoe, Mobile Dimension sawmill, 066, 046 mag, 044, 036mag, 034, 056 mag, 075, 026, lewis winch
Offline tantoy
« Reply #6 on: November 03, 2014, 09:46:51 AM »
Welcome David. Please post some pictures of your tree farmer if you have a chance.
1968 Garrett 20 Skidder
1991 Ford 1920 Tractor/Loader
2000 Takeuchi tb135 Excavator
Stihl 020, 041 Super, 084
Husqvarna 61, 181SE, 357XP
I got a skidder Tree Farmer C4D
Started by Grappletractor on Forestry and Logging
Last post September 17, 2021, 01:18:10 PM
by Iwawoodwork
Tree Farmer C4D Skidder - What to look for?
Started by coxy74 on Forestry and Logging
Last post January 02, 2014, 06:36:08 PM
by logging pete
tree farmer skidder
Started by bghunt on Forestry and Logging
Last post August 02, 2011, 04:55:12 PM
by HiTech
Tree Farmer Skidder
Started by deghan2172 on Forestry and Logging
Last post November 23, 2013, 11:48:24 PM
by ga jones
