Author Topic: Bar oil mistake  (Read 932 times)
Offline Lnewman
Bar oil mistake
« on: December 27, 2015, 10:35:16 PM »
 I had an interesting problem when trying to use a Stihl 211 MS   It started up   and  idled just fine but died when I pulled throtol trigger to rev it up.   Then I discovered I had forgotten to tighten the Cap to the bar oil securely and all the oil  had run out    I filled up the oil again and after that the saw ran just fine both at idol and at hi.   Do saws have some Shut down mechanism that keeps the chain from revolving if there is no bar oil ?
Stihl 170, 210MS, 290MS, 441MS and Hudson bandsaw
Offline beenthere
Re: Bar oil mistake
« Reply #1 on: December 27, 2015, 11:49:58 PM »
No, do not think so.
Offline Ianab
Re: Bar oil mistake
« Reply #2 on: December 28, 2015, 01:19:35 AM »
I don't think so, but the chain will jam up if it runs out of oil, and not spin. A little saw probably doesn't have the power to spin the dry chain, so it just stalls. As long as you didn't persevere and burn up the clutch there is probably no harm done.
A DIY mistake
Started by petefrom bearswamp on Chainsaws
Last post January 20, 2019, 03:15:57 PM
by Air Lad
Did I make a mistake
Started by Cumberlandcat on Sawmills and Milling
Last post January 04, 2021, 05:09:42 PM
by Bradm
Rookie mistake(s)
Started by jpad_mi on Sawmills and Milling
Last post July 07, 2007, 09:26:41 AM
by Furby
My mistake your gain
Started by Dean Hylton on Chainsaws
Last post December 27, 2004, 11:35:31 AM
by Chris J
