Author Topic: Looking to get info and some knolage on c4 tree farmers.  (Read 16935 times)
Offline thecfarm
Re: Looking to get info and some knolage on c4 tree farmers.
« Reply #120 on: April 13, 2018, 09:02:12 PM »
Yea,what are you doing with that stuff. ???
Looks like wood I haul out for my OWB. The sap wood is all gray like mine too. I chased down many trees like that on my land. One reason why I bought the OWB. I need something to burn dead wood in. I have my eye on a few more that are not going to live.
Offline logman81
« Reply #121 on: April 15, 2018, 09:02:03 AM »
This wood was felled by the landower over a year ago as a select cut. I have four different sorts, tree length firewood, pine pulp, and saw logs and some freshly cut oak saw logs. I dont have a place yet to sell the blue stained logs im thinking its going to be tough. The pulp place has a max of 20" so anything bigger has to go somewhere else.
Precision Firewood & Logging
Offline 47sawdust
« Reply #122 on: April 15, 2018, 10:11:29 AM »
Yeah,you need a special market for blue stained and maybe wormy pine.The pine borers make quite a racket when they get going,probably won't hear them over the sound of the skidder,tho.
Mick
Offline thecfarm
« Reply #123 on: April 15, 2018, 10:18:27 AM »
That wood behind the skidder is all quiet now. Those bores have come and gone. Too bad that guy did all the felling. I have no idea how much is on the ground,but that cost him some money. ???
I'm sure no expert,but that looks like more than a year to me. I know,you are going by what he told you. My pine is worth more than hardwood to me.
Offline logman81
« Reply #124 on: April 15, 2018, 10:50:39 AM »
Yes not going to be easy to find a buyer for the blued saw logs. I totally agree the smart thing would of been to hire me to do the entire job start to finish. I also agree he lost alot of money by doing it like that. This job is 20 acres of 400 available. I estimate about 10,000bft maybe a little less of the blue stained logs 20 or so cords of firewood and about 4 to 5 tri axle loads of pine pulp.
Offline 47sawdust
« Reply #125 on: April 15, 2018, 11:18:07 AM »
logman,I've sawn quite a bit of pine that was not fresh,most all for personal use.Yes it was blue and yes there were worm holes but mostly in the jacket boards.You could try CL,someone like myself in your area might be able to make something out of them.Good luck,it's time you caught a good break.
Mick
Offline chep
« Reply #126 on: April 15, 2018, 01:20:25 PM »
Is he paying you to do this? I hope so!
Offline logman81
« Reply #127 on: April 15, 2018, 06:04:28 PM »
Unfortunately no he is not im buying the tree length in good faith that i have a steady job on his 400+ acres.
Offline Outlaw
« Reply #128 on: April 15, 2018, 08:40:19 PM »
New to the forum, like to say hello!! I was curious if you had pic of the brake band that you put in. I just got my brake and refurbished and there was no back tab on it. Had a new one made but have no idea how it originally was in stalled.
TK 1600, old logging equipment,  sthil chainsaws
Offline logman81
« Reply #129 on: April 15, 2018, 09:42:59 PM »
Should look like this
Offline Outlaw
« Reply #130 on: April 15, 2018, 10:02:43 PM »
Did you have the tab on back? My guess is mine never had one on it, my band was skinny on on side and brand new on the other.  I bought it used and looks like there should be a bolt in the back to hold it center. Thanks for the reply!!! Thought I was the only one to ever own a c4 till I found this forum!!!
Offline Outlaw
« Reply #131 on: April 15, 2018, 10:15:58 PM »
A little back round. I was skidding a load of logs out and the motor died like right now. The bracket that holds the sand on snapped.  My guess is there was nothing  to hold the band center on the back of the band and when it caught nothing good happened.
Offline Outlaw
« Reply #132 on: April 15, 2018, 10:16:59 PM »
That's tthe pic of my fix, hope it will hold!!
Offline logman81
« Reply #133 on: April 16, 2018, 07:38:24 AM »
Thier should be slotted bolt on the back side to hold the band center. It is slotted because it is supposed to be safty wired to prevent it from backing out. Your repair should hold up as lond as your weld is good. I completely rebuilt my whole brake system and it works for me.
Offline Outlaw
« Reply #134 on: April 16, 2018, 08:13:26 AM »
Thanks for the info!
Offline logman81
« Reply #135 on: April 16, 2018, 08:26:47 AM »
Any time glad i could help.
Offline JustinW_NZ
  • Just Hacking and stacking.
    • Logs2Lumber
« Reply #136 on: April 18, 2018, 03:44:22 AM »
New planitary on the way be at my door step tomorrow.
Can I ask where you got it from?
My I can show a very similar picture with busted planatry bits everywhere :(
Good to  see another c4 out and about!
Mines gathering dust currently sadly..
Gear I run;
Offline Riwaka
« Reply #137 on: April 18, 2018, 05:24:53 AM »
Probably try one of the NA forestry machine parts suppliers. Measure all the dimensions to match up what they might have.
e.g Timberparts  Timberparts, used forestry equipment parts and components specialists
A local gear cutter could probably remake the gears necessary.
Offline logman81
« Reply #138 on: April 18, 2018, 05:43:48 AM »
I got it slightly used from a guy that works on forestry equipment. Harolds in maine has them but super expensive. And the old c4 is doing what its meant to do.
Offline mike_belben
  • Pulp Friction
« Reply #139 on: April 18, 2018, 08:55:52 AM »
I always did hope an old broach and hobb would cross my path at the scrap yard but it never did happen.
Revelation 13:11-18
Shout-out to New Mexico Tree farmers...
Started by chain on General Board
Last post December 29, 2010, 08:15:26 PM
by chain
2010 American Tree Farmers of the Year
Started by Tom on Forestry and Logging
Last post May 25, 2010, 08:58:04 PM
by Magicman
C4 Tree Farmer Info
Started by GUEDOZ on Forestry and Logging
Last post June 17, 2012, 09:57:56 PM
by lumberjack48
C4d tree farmer forwarder info
Started by logman81 on Forestry and Logging
Last post August 14, 2018, 04:33:47 PM
by logman81
