Looking to get info and some knolage on c4 tree farmers.
Started by logman81, October 17, 2017, 05:15:11 PM
47sawdust
logman,I've sawn quite a bit of pine that was not fresh,most all for personal use.Yes it was blue and yes there were worm holes but mostly in the jacket boards.You could try CL,someone like myself in your area might be able to make something out of them.Good luck,it's time you caught a good break.
Mick
chep
logman81
Unfortunately no he is not im buying the tree length in good faith that i have a steady job on his 400+ acres.
Precision Firewood & Logging
Outlaw
New to the forum, like to say hello!! I was curious if you had pic of the brake band that you put in. I just got my brake and refurbished and there was no back tab on it. Had a new one made but have no idea how it originally was in stalled.
TK 1600, old logging equipment,  sthil chainsaws
logman81
Outlaw
Did you have the tab on back? My guess is mine never had one on it, my band was skinny on on side and brand new on the other.  I bought it used and looks like there should be a bolt in the back to hold it center. Thanks for the reply!!! Thought I was the only one to ever own a c4 till I found this forum!!!
Outlaw
A little back round. I was skidding a load of logs out and the motor died like right now. The bracket that holds the sand on snapped.  My guess is there was nothing  to hold the band center on the back of the band and when it caught nothing good happened.
Outlaw
logman81
Thier should be slotted bolt on the back side to hold the band center. It is slotted because it is supposed to be safty wired to prevent it from backing out. Your repair should hold up as lond as your weld is good. I completely rebuilt my whole brake system and it works for me.
Outlaw
logman81
JustinW_NZ
Quote from: logman81 on April 10, 2018, 07:18:20 PM
New planitary on the way be at my door step tomorrow.
Can I ask where you got it from?
My I can show a very similar picture with busted planatry bits everywhere :(
Good to  see another c4 out and about!
Mines gathering dust currently sadly..
Gear I run;
Riwaka
Probably try one of the NA forestry machine parts suppliers. Measure all the dimensions to match up what they might have.
e.g Timberparts  Timberparts, used forestry equipment parts and components specialists
A local gear cutter could probably remake the gears necessary.
logman81
I got it slightly used from a guy that works on forestry equipment. Harolds in maine has them but super expensive. And the old c4 is doing what its meant to do.
mike_belben
I always did hope an old broach and hobb would cross my path at the scrap yard but it never did happen.
Praise The Lord
logman81
jason.weir
Anyone ever tried someone like Boston Gear (Speed Reducer, Gear Drive, Variable Speed Drives | Boston Gear)?  They have a huge selection & I wonder if the gears might be standard off the shelf items.
If you can get the gears reasonable enough, relatively inexpensive bearings, seals & machine work will take care of the rest.
logman81
Never tried i seem to have no trouble finding parts for it. I do need to find a new output seal for the pto on the Braden winch.
logman81
Haven't posted in a little bit but here is a few pics of the fun repairs i have been doing while working on this job.
mike_belben
Praise The Lord
bushmechanic
My goodness you lost two planetaries already? Well now that certainly took the cream off that machine I bet! At least you now know what's going back into it.
logman81
I broke one planitary and one spindle, the other side was a wheel seal. But yes all new parts and alot of love. Still cheaper than a new machine payment and they dont make them this small anymore. Sooner or later everything will be new and have no issues and ill have a nice vintage skidder to log with.
Grappletractor
logman81
Sold it a year ago to a guy in PA it's now back up for sale there at one of the equipment sales places.
logman81
if someone here were to buy it they would be getting a pretty solid old c4 I put alot of money into making it nice.
