Problems with Wood-Mizer Accuset 2
Started by mstahl, October 08, 2017, 06:40:58 PM
Dave Shepard
When checking voltage, make sure the glows plugs aren't cycling on diesel mills.
petefrom bearswamp
Regarding the old style fuses, Mine had the upper one work loose swivel down and short out on the lower one at about 125 hrs. this was in about early 2009
Expensive fix with new style fuses and a new H bridge.
I am convinced that it was an assembly error at the factory.
Kubota 900 RTV
Polaris 570 Sportsman ATV
57 acres of woodland
CCCLLC
When sawing with Accuset 2, pattern mode, drum switch needs to be bumped twice for next set. Is this a safety setup or faulty drum?
YellowHammer
Mine only has to be bumped once for next drop.
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
PAmizerman
Hydraulics everywhere
Woodmizer edger 26hp cat diesel
Traverse 6035 telehandler
Case 95xt skidloader
http://byrnemillwork.com/
WM bms250 sharpener
WM bmt250 setter
