Author Topic: What are new blades good for?  (Read 1888 times)
Offline moodnacreek
  • Sawin by the notches
Re: What are new blades good for?
« Reply #20 on: July 29, 2022, 10:00:17 PM »
Buy a good coin finder and check you logs before they get near the mill or any metal. I keep 2 , one in the log truck [picker] and one in the mill. I could not operate without them.
Offline caveman
  • In the land of the blind the one eyed man is king
« Reply #21 on: July 29, 2022, 10:13:27 PM »
I installed a new blade last week to try to quickly knock out a few 4x4's a repeat customer ordered.  While sawing the first pecker pole, I nearly stalled the Yanmar and knocked the set out of the blade by 1/4".  I ended up cutting the blade out with an angle grinder and removing the log was tricky since I had six more logs between the mill and the tractor.
  A few knives that I made out of saw blades:  I've got a couple that I use when cooking large quantities of food.  They hold an edge well.
Offline chet
« Reply #22 on: July 29, 2022, 11:02:24 PM »
This end of da UP of Michigan is an old Iron and Copper mining area. I think it was part of the culture back then to nail porcelain insulators to every tree, and if they missed one, attach lots of barbed wire. Your band would stand a better chance hittin' an imbedded  '56 Buick Roadmaster than that tiny insulator.   :D
Offline RAYAR
  • Retired May 2/19 more time to play with my mill
« Reply #23 on: July 30, 2022, 02:17:46 AM »
...On the HM126, the dogs are on the opposite side of the track from the operating side so the log hides the dogs.
Turn your carriage around 180 degrees and they'll be on the operator side, then watch out for your back stops. ;)
mobile manual mill (custom build) (mods & additions on-going)
Custom built auto band sharpener (currently under mods)
Husqvarna 50, 61, 254XP (and others)
96 Polaris Sportsman 500
2006 Ranger 4X2 w/cap, manual trans (408,000 Km)
Offline boonesyard
  • I've got a little sawdust in my pocket
« Reply #24 on: July 30, 2022, 08:37:07 AM »
A big lag bolt in an elm made short work of some interesting blade geometry. All the teeth are bent the same direction and are rolled over past 45 degrees. No stress in figuring out what to do with this one
LT50 wide
Riehl Steel Edger
iDRY Standard kiln
BMS 250/BMT 250
JD 4520 w/FEL
Cat TH255 Telehandler
lots of support equipment and not enough time
"I ain't here for a long time, I'm here for a good time"
Offline Percy
  • Resident trouble maker
« Reply #25 on: July 30, 2022, 10:51:57 AM »
Sometimes when Im opening a box of brand new blades, Im tempted to just fold and bust a couple right off with a hammer/whatever. Could possibly save some time as it seems  the rocks/railroad spikes, horse shoes etc can smell new blades easily...
Offline GAB
« Reply #26 on: July 30, 2022, 11:32:58 AM »
Nice museum piece you have there.
In my experience I find a newly remanufactured blade works just like a new one at finding trash.
GAB
Offline Crossroads
  • letís make some sawdust
    • K Bales Enterprises llc
« Reply #27 on: July 30, 2022, 06:13:40 PM »
Nice knives Caveman! I forge welded some blade material together right before I moved to Idaho and never did anything with it. Thereís a good chance that Iíll have a place to set up my forge this winter and Iíll try to finish it. All of the knives Iíve made at this point have been material removal with 1095. To bad I gave them all away and didnít keep one for myself. Now I get pictures with my knives with dead animals every fall.
2017 LT40 wide, BMS250 and BMT250,036 stihl, 2001 Dodge 3500 5.9 Cummins, l8000 Ford dump truck, hr16 Terex excavator, Farmi logging winch, Valley je 2x24 edger, Gehl ctl65 skid steer
Offline caveman
« Reply #28 on: July 30, 2022, 11:02:33 PM »
Thanks, I've got a coal forge that I eventually would like to learn to use to make things, especially knives.  So far, the knives I've made have been pretty basic - just remove everything that does not look like a knife blade and put a handle on it.  The knives pictured were made for my senior FFA officers the year all of our students were sent home in March 2020.  The seniors went home for spring break and missed a lot of their senior year' events (grad night, prom, awards ceremonies and banquets) when school did not resume for us in person until August.
Caveman
Offline YellowHammer
  • Sawing is fun for the first couple million boards.
    • Hobby Hardwood Alabama
« Reply #29 on: July 31, 2022, 08:25:45 AM »
@caveman
So you just ground them to shape and they worked?  What about hardening?  Do you heat treat and quench, air quench, or use them as is?  They look great.  What thickness were the bands originally, or did you find one thickness works better than another?  As many times as I'ver been cut by a band, I keep telling Martha I ought to make a knife out of them!  I know they will cut, they've bled me more than once or twice.
YellowHammerisms:
Take steps to save steps.
If it wonít roll, its not a log; itís still a tree.  Sawmills cut logs, not trees.
Kiln drying wood: When the cookies are burned, theyíre burned, and you canít fix them.  So donít burn the cookies.
Sawing is fun for the first couple hundred boards.
Offline Stephen1
  • Where there is a will, there is a way!
    • muskoka Sawmill
« Reply #30 on: July 31, 2022, 08:39:57 AM »
@caveman
Yes please tell us the recipe for making a knife. Your right YH , this is the 1st year I have been wearing shorts sawing. My shins are a mess from flipping blades open and closed,  I like the shorts but i'm tempted to go back to long pants. But then I end up with all sorts of holes in my pants. lol
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #31 on: July 31, 2022, 09:01:30 AM »
I have no idea how it made this pattern??  ::)  ???
Offline beenthere
« Reply #32 on: July 31, 2022, 01:26:24 PM »
Again?  Not too long ago saw one similar.
Offline Crossroads
« Reply #33 on: July 31, 2022, 03:53:10 PM »
I
Here are a few examples of the knives that Iíve made. They were all material removal with 1095 except the one balanced on the deer horn, it was a file. They were all quenched in oil then 2 cycles of heat treat for 2 hours at 500į if I remember correctly.
Offline caveman
« Reply #34 on: August 02, 2022, 10:26:08 PM »
Those knives are far superior to any I've made.
 Robert, generally, I've just grinded anything that did not look like a knife blade away.  I keep a can or a bucket of water close to the grinder when rough grinding to quench the blade.  As I get close to a knife shape, I take a little more time to keep the blade from getting too hot.  After it is roughly shaped, I start grinding an edge using a coarse, 60 or so grit belt.  The ones I've previously made were out of .045 and .050 blades but the .055 should be even better unless you are shooting for a fillet knife.
Caveman
Offline Crossroads
« Reply #35 on: August 02, 2022, 11:17:32 PM »
Thank you, I hope to get back into it soon. Unfortunately I wonít be able to take one of my own custom knives to Alaska with me moose hunting in September.  My partner will have the one I made for him though.
A Good Use for Scrap Blades?
Started by Chris Burchfield on Sawmills and Milling
Last post September 12, 2006, 11:24:10 PM
by woodbowl
question
Bandsaw Blades - Who sends sample blades to try out?
Started by Ozarkian on Sawmills and Milling
Last post April 01, 2012, 06:50:08 PM
by Magicman
What is a good light weight chainsaw? I have a good large powerful saw.
Started by TNMailman on Chainsaws
Last post August 28, 2021, 06:46:54 AM
by Al_Smith
question
Blued blades VS shiny blades
Started by woodbowl on Sawmills and Milling
Last post January 17, 2006, 01:30:17 AM
by woodbowl
