Author Topic: Seeking cedar strips  (Read 2096 times)
Offline kantuckid
Re: Seeking cedar strips
« Reply #20 on: April 29, 2021, 02:45:27 PM »
I would choose redwood given your location. Do table sawn strips and attach as makes sense to the van ceiling. Could easily do a half lap joint using a common router bit to assist with coverage and an easy install.
Offline Cedarman
    • Cedarusa
« Reply #21 on: May 03, 2021, 07:00:07 AM »
We can supply clear cedar in lengths up to 8'.  For long lengths we can supply, but will have some small knots if we have time to grade.
Shipping is not a problem, but might be a little expensive.
If you have a place than can put the lumber in a kiln and heat it to 150 degrees or more, you can drive the oils off, reducing the aroma somewhat.  coating the wood on all sides will hold a lot of the oils in place.
If you have a final material list.  Thickness, widths, lengths, and whether planed or left with band sawn texture, I will be happy to quote.
Offline Howdy
« Reply #22 on: May 05, 2021, 11:08:29 PM »
Thank you for the information, suggestions, and offers.
I am converting surface rust, priming, and painting everything now, and will be getting the engine in before I worry about finishing the interior.  Trying to find an engine is not easy unless you have a big budget.  I am trying to find a LM7 (5.3l chevy or GM engine) with an automatic trans. but if that proves to be too expensive my mechanic suggests I go old school with a 350ci.  whichever I find first that I can afford will win the bet.
Offline samandothers
« Reply #23 on: May 06, 2021, 09:13:24 AM »
Converting rust, with Ospho or something similar?
Offline Howdy
« Reply #24 on: May 11, 2021, 01:36:33 AM »
yep, Ospho then priming.
Looks good and seems to do the job.
moved
MOVED: Seeking cedar strips
Started by Wildflower on For Sale
Last post April 16, 2021, 02:14:30 PM
by Wildflower
Baton Strips
Started by POSTON WIDEHEAD on Sawmills and Milling
Last post August 21, 2014, 11:11:17 PM
by barbender
Inlay strips
Started by Larry on General Board
Last post November 20, 2004, 01:45:03 PM
by SwampDonkey
Batten strips
Started by Bruno of NH on Sawmills and Milling
Last post April 13, 2018, 10:27:19 PM
by Darrel
