372 XP clones gas and oil caps?
Started by Satamax, August 19, 2022, 03:26:37 PM
Satamax
Hi everybody.
I have a three years old holzforma 372. And since day two, i've been annoyed by the leaky gas and oil caps.
Did you have the same issue?  What was your fix?
Thanks a lot guys!
French CD4 sawmill. Mecalac digger, with grapple. Self moving hydraulic boom crane. And a Brimont TL80 CSA.
Spike60
Simple fix ought to be to get a couple OEM Husky caps. The seals/o-rings on some of the aftermarket caps are often too hard to provide a tight seal.
Husqvarna-Jonsered
Ashokan Turf and Timber
845-657-6395
Satamax
I'll have to look into that. Thanks a lot.
I was wondering if anybody had changed the o rings.
Kelly B
I'd go buy OEM o rings and install on caps that should cure the issue.mine leak a tiny bit as well. I plan on doing the same thing.....
Satamax
