Author Topic: piston stops and life lessons...  (Read 728 times)
Offline bluthum
  • Tick magnet.
« on: October 30, 2022, 11:51:58 AM »
I've used nylon cord as a piston stop for years and always found it humorous reading about people getting the cord stuck. Seems like that would require carelessness or ineptitude I reasoned.
Sure enough I joined the ranks of the inept a couple days ago after locking a piston solid with a piece of the first nylon rope I grabbed, a piece of starter rope. Went right into the exhaust port. The muffler was removed to see the end of the rope but the piston was still above the port, stuck way past moving with the starter.   I finally got it moved down with a soft punch striking on the clutch, rope came right out and now all's well.
A good dope slap from reality seems to be an excellent arrogance reducer at times. It's a plus when the arrogance reduction is cheap too, makes it much easier to laugh at ones self, haha...
Offline barbender
Re: piston stops and life lessons...
« Reply #1 on: October 30, 2022, 12:04:35 PM »
Ah yes, a good serving of humble pie has done me lots of good over the years.
Offline Real1shepherd
« Reply #2 on: October 30, 2022, 12:10:25 PM »
I always use a cut V-belt and never had an issue. Pretty hard to get that down a transfer port, but I guess anything is possible.;D
Kevin
Online lxskllr
  • dummy with saw
« Reply #3 on: October 30, 2022, 12:32:27 PM »
I haven't had a chance to use it yet, but I remember you mentioning Vbelt before Kevin. That sounds like a great idea to me.
Offline bluthum
  • Tick magnet.
« Reply #4 on: October 30, 2022, 07:11:46 PM »
Yeah Real1shepard, that v-belt idea is on my list to try next time. Sometimes the simplest things are the hardest to improve on, I think that one is a score.
Online Southside
    • White Oak Meadows
« Reply #5 on: October 30, 2022, 09:55:37 PM »
Can you explain what you mean by this ? Trying to understand the reason.
White Oak Meadows
Offline Wlmedley
  • Endeavor to persevere
« Reply #6 on: October 30, 2022, 10:29:11 PM »
I think they’re using this to put down in spark plug hole to lock engine to be able to remove clutch or flywheel.Someone correct me if I’m wrong.I know a screwdriver in the flywheel fins will break them.Don’t ask how I know  :laugh:
Bill Medley WM 126-14hp , Husky372xp ,MF1020 ,Homemade log arch,Yamaha Grizzly 450,GMC2500,Oregon log splitter
Offline rusticretreater
  • I finally have enough wood!
« Reply #7 on: October 30, 2022, 10:44:32 PM »
I have a dedicated rope for doing this. Its a bit thicker than the pull cord.  I made a knot on the end to keep it from going through the cylinder ports.  I try to remember to bring the piston close to TDC before putting the cord in.
Kubota BX25
Homemade Log Arch
Husqvarna 562xp
Online Southside
    • White Oak Meadows
« Reply #8 on: October 30, 2022, 10:57:50 PM »
Ahh, makes sense
White Oak Meadows
Offline teakwood
  • Switzerland
« Reply #9 on: November 01, 2022, 07:53:19 AM »
Of course if you us a impact gun it's way less abusing in the parts than doing it with a big wrench trying to brake free the nut.
Maybe it even brakes free without jamming the piston
Life lessons from a 6 y/o
Started by WV Sawmiller on General Board
Last post December 26, 2018, 08:28:38 PM
by florida
Replace piston rings, piston, or cylinder?
Started by Spruce_Goose on Chainsaws
Last post May 11, 2014, 10:28:50 PM
by Al_Smith
Two lessons for all of us
Started by low_48 on General Board
Last post April 30, 2008, 09:32:43 PM
by Burlkraft
Possible Lessons Learned
Started by jmur1 on Firewood and Wood Heating
Last post November 01, 2020, 10:45:23 AM
by jmur1
