SPACE AVAILABLE
I ended up changing the power vent configuration quite a bit
Quote from: blackhawk on March 22, 2023, 01:52:15 PMI ended up changing the power vent configuration quite a bitYes you did. The power vent is installed backwards, it is supposed to blow out of the kiln not into it.
How many board feet did you put in the kiln ?
Started by Ron Scott on Forest Education
Started by otternorth on Sawmills and Milling
Started by FeltzE on General Board
Started by Piston on Timber Framing/Log construction
