Author Topic: Husky Rancher 61 Side cover with chain brake needed.  (Read 1567 times)
Offline MartyParsons
  • Wood-Mizer Service and sales PA, VA, MD, WV others
« on: November 25, 2011, 09:26:49 PM »
Hello,
I need a clutch side cover with the chain break and all the parts. Very Early model 61 Rancher. It has a thick wire or Steel chain break lever. The cover is cream color I guess it could of been white at one time.
Marty
A pessimist sees difficulty in every opportunity; an optimist sees opportunity in every difficulty. -Winston Churchill
Offline smwwoody
  • Makeing round wood square
Re: Husky Rancher 61 Side cover with chain brake needed.
« Reply #1 on: November 28, 2011, 08:59:30 AM »
Marty
I can get you a new orange one cheep. Or if you have one from a 272 it will fit. I will look and see if I may have a good used on
Woody
Full time Mill Manager
Cleereman head rig
Cooper Scragg
McDonugh gang saw
McDonugh edger
McDonugh resaw
TS end trim
Pendu slab recovery system
KJ4WXC
Offline smwwoody
« Reply #2 on: November 28, 2011, 01:37:52 PM »
Marty
Call me if you still need one I think I have a few old 272s that should have a good cover on them. If not a new aftermarket one is only about $40 complete
Woody
Cleereman head rig
Cooper Scragg
McDonugh gang saw
McDonugh edger
McDonugh resaw
TS end trim
KJ4WXC
« Reply #3 on: December 02, 2011, 04:22:03 AM »
Roger was calling yesterday. The parts are no longer available through Husky. Are you sure what you have will fit?
M
« Reply #4 on: December 06, 2011, 07:10:41 PM »
Roger said it must be older than 1982.
Serial # is 051606 which should make this unit a 1980
The top must be white not gray
part # is 501 2009-01 complete part
other part # make up the above #
501 4185-01 band
501 1807-01 spring
281 6192-01 washer
501 4193-02 bolt
thanks for checking.
Marty
Offline smwwoody
« Reply #5 on: December 06, 2011, 08:31:58 PM »
I have one of those white top 61 ranchers with the the metal break handle.  I put a side cover from a 272 with the plastic handle on it and it seems to work ok i will have to check and make sure but now that I think about it the break is not inertia activated anymore.  the old metal ones had a thumbscrew that you adjusted close to the handle bar so if the anti vibe mounts flexed enough it would bump the break handle and activate the break.  I hope that made sense.  (it did in my head)
Woody
Cleereman head rig
Cooper Scragg
McDonugh gang saw
McDonugh edger
McDonugh resaw
TS end trim
KJ4WXC
Husky 66 brake cover.
Started by Dave Shepard on Chainsaws
Last post January 10, 2014, 07:04:48 AM
by Spike60
WTB: Makita 520i or 540 Chain Brake Cover
Started by MakitaDolmar on Wanted
Last post April 09, 2021, 04:00:53 PM
by MakitaDolmar
Stihl MS 660 cracked mount near the chain gaurd cover, left side
Started by tamarack64 on Chainsaws
Last post June 19, 2015, 06:26:52 PM
by weimedog
Husky Rancher 455 factory chain
Started by sprintfan11 on Chainsaws
Last post April 29, 2009, 08:48:41 PM
by RANGERDALEXP
