Author Topic: John Deere 1010D forwarder strange issue  (Read 3039 times)
Offline bushmechanic
  • Someone else has it worse than you.
Re: John Deere 1010D forwarder strange issue
« Reply #20 on: May 26, 2019, 06:03:31 AM »
Mike a 3406E I guess would put that truck mid 90's to early 2000's, I'm not sure if there would be a VCU (vehicle control unit) in that year of truck but it would be a good place to start. Those fan switches on the older trucks were pretty simple. I would look at a wiring diagram to see if the power supply to the relay is not paired up with something else, like the ECM. Some greenie's on a wire may pass enough current to work the ECM but more draw from something else will lower the current to where it affects something else in the circuit. Always remember a strand of wire will carry 12 volts but little current.
Offline mike_belben
  • Pulp Friction
« Reply #21 on: May 29, 2019, 11:56:37 PM »
Hasnt recurred lately so im gonna pretend that issue and i never met.
Isaiah 48:10
John Deere 340D Forwarder
Started by Horselog on Forestry and Logging
Last post April 02, 2015, 10:24:46 PM
by BargeMonkey
John Deere 540GIII Air conditioning issue
Started by TheDirt on Forestry and Logging
Last post May 27, 2021, 04:27:24 PM
by Hogdaddy
John deere 648h fuel issue
Started by Brewin1808 on Forestry and Logging
Last post February 12, 2020, 02:53:43 PM
by treemuncher
1997 John Deere 648G Steering Issue
Started by spinner on Forestry and Logging
Last post April 23, 2020, 07:45:38 PM
by kiko
