Author Topic: John Deere 540GIII Air conditioning issue  (Read 330 times)
Offline TheDirt
« on: May 26, 2021, 06:36:27 PM »
Lost my A/C the other day, the compressor is not cooling the line out, tried recharging at the port on the compressor but after a few seconds it blew freon out of the relief valve. I'm assuming that means the system is not low on refrigerant and i was overfilling it. I've heard that these systems can be costly to fix, I don't know much at all about A/C systems, if anyone has had any expierience with these I'd appreciate the input! thanks!
Offline tamarackman
Re: John Deere 540GIII Air conditioning issue
« Reply #1 on: May 26, 2021, 07:07:01 PM »
I have no knowledge of the ac system in the 540G or any other skidder. But I have fixed a few too many car ac systems. If the pressure is good then the next thing to check is the clutch. Is it engaging or not. Sometimes the clutch will freeze up in the off position (not used during the winter time). Other times, the clutch material becomes thinner making it unable to get good contact. On some cars, it's just a matter of either taking it apart to free it up or removing spacers to get the clutch to move in closer.
Offline kiko
« Reply #2 on: May 26, 2021, 07:15:35 PM »
If freon was charged on top of air in the system that would cause high side pressure to spike. There is a high pressure switch that should kill the clutch before the relief valve opens.  A set of gauges is necessary to diagnose.  If you have gauges share the readings.
Offline chevytaHOE5674
  • Forester
« Reply #3 on: May 26, 2021, 11:28:48 PM »
X2 what Kiko said. You need a set of gauges to properly diagnose and charge an AC system.
Offline Hogdaddy
« Reply #4 on: May 27, 2021, 04:27:24 PM »
The only problem I have with skidder AC, is that i dont have any... :). joking, hope you get it figured out
If you gonna be a bear, be a Grizzly!
05 Timberjack 360D/ John Deere 540gIII fault codes
Started by TheDirt on Forestry and Logging
Last post March 26, 2019, 09:04:33 PM
by kiko
John deere 648h fuel issue
Started by Brewin1808 on Forestry and Logging
Last post February 12, 2020, 02:53:43 PM
by treemuncher
John Deere 1010D forwarder strange issue
Started by bushmechanic on Forestry and Logging
Last post May 29, 2019, 11:56:37 PM
by mike_belben
1997 John Deere 648G Steering Issue
Started by spinner on Forestry and Logging
Last post April 23, 2020, 07:45:38 PM
by kiko
