Author Topic: Cyclone dust extraction system  (Read 1852 times)
Offline Walnut Beast
Re: Cyclone dust extraction system
« Reply #20 on: August 03, 2022, 09:12:46 AM »
I will definitely keep that in mind. I like that idea 👍
« Reply #21 on: August 04, 2022, 04:53:56 AM »
Big shout out to Yellowhammer!! You got my wheels turning the first time and then the second time. Now it is even better than before. The top one relives enormous amount of pressure  but the second one doesnít because itís screen is on the side of the flow but with a little reduction in size on the outlet end it creates enough reduction that the exhaust air really comes out on the second one so now everything just drops out very nice. There is no effect on the suction side
Offline YellowHammer
  • Sawing is fun for the first couple million boards.
    • Hobby Hardwood Alabama
« Reply #22 on: August 04, 2022, 07:49:58 AM »
That is a great system!  I love the double outlet idea.  Well done!
YellowHammerisms:
Take steps to save steps.
If it wonít roll, its not a log; itís still a tree.  Sawmills cut logs, not trees.
Kiln drying wood: When the cookies are burned, theyíre burned, and you canít fix them.  So donít burn the cookies.
Sawing is fun for the first couple hundred boards.
Offline Don P
    • Calculator Index
« Reply #23 on: August 04, 2022, 07:55:32 AM »
It looks like you are beginning to build up on the screen, that is going to be the problem, an upturn and self dumping screen? It also looks like you are on the way to making a cyclone. I've got layout methods and specs if you go that direction. Quite similar methods to making a moonshine still  :D
The future is a foreign country, they will do things differently there - Simon Winchester
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #24 on: August 04, 2022, 09:12:31 AM »
So, if you get tired of woodworking, you can make liquor?
Offline Don P
    • Calculator Index
« Reply #25 on: August 04, 2022, 05:28:16 PM »
Always good to be cross trained  ;D.
Offline WDH
« Reply #26 on: August 04, 2022, 05:36:56 PM »
I always figured that you were a man of some flexibility and knew that you were multi-skilled.
Offline Don P
    • Calculator Index
« Reply #27 on: August 04, 2022, 09:48:41 PM »
Sawing is less work  :).
The book with cyclone layout and all sorts of fan stuff is still in print, cheap too, worth it for the understanding whether you build from it or not;
How to Design & Build Centrifugal Fans For the Home Shop (gingerybookstore.com)
« Reply #28 on: August 04, 2022, 10:38:17 PM »
The link to the book is sold out Don 😂
help needed to find dust extraction specs for a 4sider
Started by timbatrader on Drying and Processing
Last post October 05, 2014, 06:17:44 PM
by timbatrader
A Thien Cyclone Dust Separator
Started by Brian_Weekley on General Woodworking
Last post February 09, 2017, 04:28:23 PM
by 21incher
Cyclone Dust Collector Problems
Started by Lohok27 on Sawmills and Milling
Last post July 27, 2011, 10:08:38 AM
by Lohok27
Grain auger for cleaning out dust cyclone
Started by trim4u2nv on Drying and Processing
Last post January 02, 2009, 03:07:38 PM
by StorminN
