Pear Preserves
Started by WV Sawmiller, October 05, 2023, 09:27:21 PM
WV Sawmiller
   We have a little wild pear tree on the upper side of our pasture. The pears are small - about the size of an egg - and pretty hard. Usually it only has a handful of pears on it and I might eat 1-2 as I ride my AYV by but this year the limbs were hanging with them so I went up and harvested half a 50 lb feed sack full and brought them back and peeled and cut them up. I had about 9-1/2 quarts of pieces My wife likes pear preserves so I measured them, added 4 lbs (9 cups?) of sugar, 7 tablespoons of lemon juice,  and a couple quarts of water and cooked them about 2 hours once they started boiling. It made 12 pints of preserves.
 Now for some hot biscuits!
cutterboy
Hot biscuits and pear preserves. Boy, that does sound good!
To underestimate old men and old machines is the folly of youth. Frank C.
21incher
Are they the Seckel Pears you use? We love them and recently planted a couple trees. Can't wait to try this.
50#!!!
That took a while to peel.  ;)
We did a bunch of peaches one year. Seem like it took forever to get them ready. They was small ones, as your pears was.
WV Sawmiller
   Wasn't that many but yes it took a long time to peel and cut up. It was half of a 50 lb feed sack. Of course they are heavier than the feed that came in the sack.
Yep, missed the half sack part.  :-[
LeeB
My favorite way to preserve fruit is with sugar and yeast.
WV Sawmiller
   To each his own. :D That would have probably been a lot easier than the way I did mine. ;)
LeeB
I doubt it. The same prep work along with primary fermentation, secondary fermentation, racking off the wine a few times to get rid of the solids and sediment, then aging and finally bottling.
WV Sawmiller
Oh, I missed the distillation step and figured for that the pears would just be crushed and fermented them the mash would be worked up. ;D
cutterboy
Quote from: LeeB on October 09, 2023, 01:00:06 PM
Lee, sometimes I'm a bit slow. I'm sitting here thinking "why would anyone add yeast to pear preserves" ::) :D :D
LeeB
I tend to preserve fruit in a liquid form.
sawguy21
A former boss made wine from scratch. If he got a batch he didn't like he would freeze it in cake pans, pour the alcohol off which fortified the good stuff. He made a delicious pear wine that had a real kick. ;D
