Split blades for WM EG200 Edger
Started by customsawyer, September 05, 2019, 03:29:34 AM
PAmizerman
Hydraulics everywhere
Woodmizer edger 26hp cat diesel
Traverse 6035 telehandler
Case 95xt skidloader
http://byrnemillwork.com/
WM bms250 sharpener
WM bmt250 setter
moodnacreek
If these saws are carbide and don't need retipping why not sharpen with a diamond file. Not that many teeth and no set or angles just straight across. What ever happened to insert tooth saws for edgers?
Crossroads
Quote from: moodnacreek on July 19, 2023, 12:49:50 PM
I'm pretty sure this is what I'm going to do when I need a touching up on my current blades. The 2 spare blades I have look pretty good on the shelf they are holding down.
rooster 58
PAmizerman,
     I'm sure that will be very useful information! BTW, only ran one piece of 6/4 red oak through it, but it never slowed down  ;)
