Author Topic: Black Locust worth cutting? $30 6" x 6" x 7'  (Read 3288 times)
Offline OffGrid973
  • Off Grid
« on: August 19, 2017, 12:52:59 PM »
Hi guys,
Ran out of white oak logs and thinking of finishing an order with black Locust. Is it worth it for $30 a post compared to how it will eat up my blades?
Your Fellow Woodworker,
- Off Grid
Offline POSTON WIDEHEAD
  • Getting old but doing it with Friends.
Re: Black Locust worth cutting? $30 6" x 6" x 7'
« Reply #1 on: August 19, 2017, 06:34:46 PM »
How many more Locust do you need to saw?
If you're trying to fill an order for a customer and need the Locust to finish his order, by all means its worth it.
Offline LeeB
« Reply #2 on: August 19, 2017, 06:38:37 PM »
Is the customer going to be ok with locust instead?
Offline Delawhere Jack
  • I ought to know better.....
« Reply #3 on: August 19, 2017, 07:08:10 PM »
Black locust isn't that bad on bands if it's fresh. If it's been laying around a year or more it can be a nightmare.
A 6x6x7' would be 21 board feet. At $30, that's $1.85/bf. A little low. Trying to price some BL for a client this past spring, the very few published prices I found ran $2.50-3.00/bf.
If it's just a couple pieces it wouldn't break you I suppose.
Offline Larry
    • Copas Sawmill
« Reply #4 on: August 19, 2017, 08:06:26 PM »
I would much rather cut black locust either green or dry than white oak.  Black locust also has a pleasant smell....makes me hungry. :D
Black locust also is usually smaller logs than white oak, seems in my case almost always.
Online WV Sawmiller
    • Green's Sawmill Services
« Reply #5 on: August 19, 2017, 11:14:06 PM »
   If I were the customer I'd be thrilled to have BL instead of WO. I have sawed little but the BL I sawed green was very easy to saw.
Offline 4x4American
  • 1234
    • Website Link
« Reply #6 on: August 20, 2017, 09:06:25 AM »
I agree with jack kinda cheap if you ask me
Boy, back in my day..
Offline JB Griffin
« Reply #7 on: August 20, 2017, 06:08:09 PM »
I see LOTS of high priced lumber and slabs for sale, I bet a lot of it is still for sale.
2000 LT40hyd remote 33hp Kubota with 6gpm hyd unit, 150 Prentice, WM bms250, Suffolk dual tooth setter
Over 3.5million bdft sawn with a Baker Dominator.
Offline LeeB
« Reply #8 on: August 20, 2017, 08:57:02 PM »
Starting sawing ERC this morning but didn't get very far with it before I blew a seal in the blade tensioner. I guess 19 years is pretty good lifespan for a seal. Got new seal kit ordered. Ordered two of them.
Offline OffGrid973
  • Off Grid
« Reply #9 on: August 21, 2017, 08:00:34 PM »
Ok guys, I appreciate the feedback.  This gentleman is part of my New Jersey wood turners association and doing a job for his church so I agree low but fare in this case. Five more fresh cut black Locust will arrive this wed.
Thanks again for the feedback. It is all greatly appreciated as I move into lumber side of things.  FYI my $100 slabs sell much quicker then $250 or "$300" so sometimes it makes sense to gain a good customer.
-chris
- Off Grid
A couple Black locust logs/poles around 5"-7" diameter - SW Michigan
Started by elitts on Wanted
Last post January 23, 2019, 08:26:51 PM
by jmouton
"Ship-Mast" Black Locust
Started by Blue Sky on Forestry and Logging
Last post November 14, 2007, 01:15:23 PM
by Daren
Landowner in Florida: the question of "what are these trees worth"
Started by dbrooks on Forestry and Logging
Last post February 28, 2017, 10:03:46 PM
by ellmoe
Peterson "Log Locust" Mill
Started by Dank11 on Sawmills and Milling
Last post July 27, 2006, 09:29:43 AM
by jpgreen
