Author Topic: Whatcha Sawin' 2023 ??  (Read 9903 times)
Offline barbender
Re: Whatcha Sawin' 2023 ??
« Reply #140 on: January 25, 2023, 12:01:28 AM »
About 1200 bf of white pine on the deck for morning.
Offline Deese
« Reply #141 on: January 25, 2023, 12:14:12 AM »
Those are some dandys right there. I bet you'll get more than 1200.
2004 LT40 Super 51hp w/6' bed extension
Cooks AE4P Edger
Cat Claw sharpener/Dual Tooth Setter
Kubota svl75-2 skidsteer w/grapple, forks, brushcutter
1977 Log Hog Knuckleboom loader/truck
Offline Don_Papenburg
  • I need money
« Reply #142 on: January 25, 2023, 06:07:10 PM »
If I remember right curly comes from yellow birch .Maybe white has curl also.
Offline barbender
« Reply #143 on: January 25, 2023, 07:32:55 PM »
Whether it saws that way I don't know, but I've seen curly grain in a lot of white birch I'm processing for firewood. Most white birch is straight grained and pops open nice, you can definitely tell the difference when you get into the curly stuff it's almost like elm.
Offline fluidpowerpro
  • Hi there!
« Reply #144 on: January 26, 2023, 12:58:31 PM »
When I looked up curly birch it said that it was caused by a genetic defect and it only grew in Finland and Russia. That must be a specific type because like many things "curly" can have varying degrees.
Change is hard....
Offline doc henderson
« Reply #145 on: January 26, 2023, 01:42:50 PM »
I have had soft maple that I believe Danny referred to as curly.  there is quilted and birds eye.  it may also be in the area of branches ect.
  • I need money
« Reply #146 on: January 26, 2023, 06:26:44 PM »
About ten or maybe fifteen years ago , I got my curly birch from the U.P. area. My guy tells me that no one is bothering to cut birch trees . He used to go to the mills and buy  the curly birch logs.
Offline Stephen1
    • muskoka Sawmill
« Reply #147 on: January 26, 2023, 06:44:32 PM »
A new customer brought these 5 slabs the other day to saw in half.  He thought it was walnut?  Is he right?
These photos are from the customer.  I forgot to take photos when we halved them.
hugs,  Brandi
I am leaning towards butternut, as it's kind of bland.
Offline richhiway
  • Rich
« Reply #148 on: January 28, 2023, 03:32:50 PM »
Cut a big pine with ant damage. Nice here in upstate NY 40 degrees and sunny.
Woodmizer LT 40
New Holland 35 hp tractor
Stihl Chainsaws
Offline richhiway
  • Rich
« Reply #149 on: January 28, 2023, 03:35:15 PM »
Some nice furniture slabs and lumber. the center went in the junk pile.
Woodmizer LT 40
Stihl Chainsaws
Offline beenthere
« Reply #150 on: January 28, 2023, 03:47:15 PM »
Quote
Ants came after the damage was caused by decay/rot in the pine. Good indicators of rotten wood.
Might make some good boards when dried and finished off nice.
« Reply #151 on: January 28, 2023, 05:42:04 PM »
my buddy Dallas wanted to know if I wanted some ERC logs?  No, I have 200 logs in my yard.  nest question would I saw them for making a table with epoxy for him and a buddy?  yes.
killing ants and flashing off some moisture.  5 inches thick.
Offline Wlmedley
  • Endeavor to persevere
« Reply #152 on: January 28, 2023, 05:55:52 PM »
A nice day up here today.Ground dried up a little so I loaded deck up with pine.Give me something to do on the next rainy day or two  :laugh: <Same tree that fell across my driveway when it was 5 degrees.Now I’ll get my revenge.br>
Bill Medley WM 126-14hp , Husky372xp ,MF1020 ,Homemade log arch,Yamaha Grizzly 450,GMC2500,Oregon log splitter
Offline Bindian
  • Gender: Female
« Reply #153 on: January 29, 2023, 01:52:06 AM »
hugs,  Brandi
Does Butternut grow in Wisconsin?
hugs,  Brandi
Mahindra 6520 4WD with loader/backhoe and a Caterpiller E70 Excavator.  My mill is a Woodmizer LT40HD Wide Diesel. An old Lull 644D-34 called Bull
My Hero is Johnny Jett
Offline Bindian
  • Gender: Female
« Reply #154 on: January 29, 2023, 01:56:05 AM »
Dang Doc, I could bring the gooseneck up and take a load off your hands.  Seriously.
hugs,   Brandi
Online firefighter ontheside
  • I like trees.
« Reply #155 on: January 29, 2023, 08:45:50 AM »
Those are neat cedar cookies, Doc.
Woodmizer LT15
Kubota Grand L4200
Stihl 025, MS261 and MS362
2017 F350 Diesel 4WD
Kawasaki Mule 4010
1998 Dodge 3500 Flatbed
Offline Resonator
  • Board Footage and Cord Woodage
« Reply #156 on: January 29, 2023, 11:11:48 AM »
Quote
Yes it does (even a town named Butternut in Wisconsin). Sawn it a couple times, makes nice hardwood boards.
« Reply #157 on: January 29, 2023, 11:47:58 AM »
Res I know you sing some country music, so when you mentioned you had sawn it, I thought it was you had seen the town of butternut, and was using the past tense for having seen it.  "sawn".   :D :D :D
Brandi, not sure it would be cost effective.  I get it free, and my buddy has about 600 more logs 20 feet long and already limbed.  He is clearing some pasture ground (about 100 acres) of these trees.  the ground was unattended for 30 + years.  Let me know if you happen to be up this way with a trailer.
Offline Resonator
« Reply #158 on: January 29, 2023, 12:42:45 PM »
Yup Doc, I've Seen it, sawn it, been there, and done that.  :D
Funny how ERC is prevalent in some areas and scarce in others. Around here, I could cut it and sell it for closet paneling all day long.
Offline chet
« Reply #159 on: January 29, 2023, 01:49:40 PM »
Tried sawin' ERC once, not gonna try than again! ::)  I started sneezin', eyes waterin' and got da itches something fierce. I'll stick to Northern White Cedar it's lots better stuff.  :D
question
Whatcha Sawin' ???
Started by Magicman on Sawmills and Milling
Last post March 06, 2019, 08:53:50 AM
by Jeff
Whatcha NOT Sawin' ???
Started by terrifictimbersllc on Sawmills and Milling
Last post September 17, 2022, 07:23:50 AM
by jpassardi
question
Whatcha Sawin' 2021 ??
Last post December 31, 2021, 10:06:28 PM
by Magicman
question
Whatcha Sawin' 2022 ??
Last post December 31, 2022, 02:04:10 PM
by GAB
