loose fuel injector
Started by woodmills1, December 16, 2007, 08:17:21 AM
woodmills1
I noticed some fluid under my tractor yesterday, and upon inspect saw tiny bubbles weeping from around the center injector on my lk 3054 Kioti.  They come from where the injector meets the head.  Any ideas on a fix, it is a dadeong 3 cly diesel.
treedog
Sounds like the injector sleeve is bad.  Had the same problem last year with 686 IH.  Not very hard to replace.  Remove injector and borrow or make a sleeve puller; install new sleeve.  Used red locktite on new sleeve or it will leak too.  Bleed the system and you should be good to go.  Treedog
