Tractor vs skid steer
Started by CX3, May 02, 2018, 10:41:15 PM
62oliver
I used my old bobcat with a grapple bucket in the bush for awhile to pull out firewood, it worked fine for the small amount I burn in a year, but if it rained any real amount I could not even move out there because it was so greasy. Same with the 310c backhoe, mostly because it is so heavy in the back, it just did not get around very good out there either if it was wet.
The 240E TJ changed all that.
  But you are asking skid steer or 4wd tractor, I would say tractor for sure.
Ground clearance is a big one and in soft ground you can get into trouble with a skid steer real fast!!
I have a Case 90xt, it weighs about 9000lbs, I wouldn't want to be stuck in the bush with that.
Husqvarna 266, Case 90xt, JD310C, TJ240E, 02 Duramax
Walnut Beast
These guys said if it wasn't for the tracked machines on the really muddy days they wouldn't be logging
stavebuyer
That ain't clay and those logs weren't layed out when it was wet unless they used a tracked helicopter.
Kodiakmac
Quote from: Walnut Beast on April 16, 2021, 06:51:47 AM
Just curious.  Why are the logs laid out like that?
Robin Hood had it just about right:  as long as a man has family, friends, deer and beer...he needs very little government!
Kioti rx7320, Wallenstein fx110 winch, Echo CS510, Stihl MS362cm, Stihl 051AV, Wallenstein wx980  Mark 8:36
mike_belben
Veener buyers roll every log
Praise The Lord
Walnut Beast
Quote from: stavebuyer on April 16, 2021, 08:04:46 AM
They do have a 450 steel track dozer and the 333 John Deere rubber track. But again if it wasn't for tracks
Nebraska
Bet it was frozen ground when they were laid out.
alan gage
I have an old Bobcat 873 with 4500 max lift capacity. I bought it soon after I tried moving logs around with my dad's 70hp Kubota (M7040).
It was a $30k used tractor and the skidloader was $10k (older and more hours) but I'll take the skidloader any day for moving logs, lumber, loading trailers, digging, and grading. Lots of attachments available to rent.
The tractor is slow to turn, light on lifting power, has clearance issues (tall) and wants to tip over if you look at it funny. Tractor always wants to tip forward and sideways. At least the skidloader just stands on its nose when it's overloaded. I've never had it want to go sideways.
I know there are more appropriate tractors for this type of work and places where they would shine over a skidloader, just giving my personal experience.
Alan
Timberking B-16, a few chainsaws from small to large, and a Bobcat 873 Skidloader.
Satamax
I've never understood the love you have with skid steer in the US.
Over here it's telehandler land, or proper loaders. Loaders, for clearing the snow in winter. I have at least 7 within 100 yards of me. Telehandlers, 6. And any telehandler reaching over 20' has stabiliser.
We use skid steer for small earth works When diggers and loaders can't quite get in the space.
And funnily enough, they're expensive.
Where i live, what you'd see everywhere.
â,, Hitachi ZW220 chaînée au déneigement de Val Tho â,, - YouTube
Saison de paille Bio 2020 (1/2) CabView Manitou MLT 741-140V+ Elite - YouTube
mike_belben
Well ..until the stimmy era they were reasonably cheap and plentiful.
Praise The Lord
Satamax
Quote from: mike_belben on April 17, 2021, 04:32:33 AM
Huh, what's the stimmy era?
Nebraska
Can't  be explained fully  here. Kind of a restricted topics thing...
Ventryjr
I was always a die hard tractor guy. Until this winter I had a buddy come with a skid steer to help me carry some logs out of the woods. Within 2 months I bought a kubota svl-75. Has 16" ground clearance, tracks and is rated to lift 2300lbs but will lift and move a lot more. Cheaper then a 75hp tractor and doesn't get flat tires.  Both have their uses but I will be using this to log more so then any of my tractors.  I only do this as a hobby and by no means have professional experience.
-2x belsaw m14s and a Lane circle mill.
mike_belben
Quote from: Satamax on April 17, 2021, 04:39:11 AM
USA has been direct depositing tremendous amounts of cash that they call "stimulus" into individual bank accounts, whether asked for or not.   It has doubled the money supply, pushed prices of everything out of sight and basically coerced a large portion of the country to quit working.  A well designed 1st class trainwreck that has been brewing since the 1960s.
Praise The Lord
Satamax
Yup. I think I got it.
"Etat providence" as we call it. I think we've invented it in France.  ;D
Walnut Beast
Quote from: Ventryjr on April 17, 2021, 08:28:24 AM
Hands on experience dictates good decisions 👍
KWood255
I have had 3 skid steers, 2 with tires (and steel tracks) and one rubber track machine. Fantastic machines on hard ground, and decent in the bush when running the tracks. For logging, unless you are going to carry logs on a grapple or forks, you are very limited to move any distance efficiently. Ground clearance is minimal, and they are rough!
I now have a 75hp Kubota 4wd tractor with loader. I'm totally impressed with the versatility. 3 point hitch attachments like the skidder winches are easy to find (pre-covid), and relatively inexpensive. I can lift a little better than 3000lbs on my loader, and have much better visibility out of my cab vs the skid steer. The skidder winch is no replacement for a TJ, but it works well.
My opinion, if a guy is going to have one machine in the yard, its a 4wd tractor all the way. Better yet, if its in the cards, one of each is always ok too!
mike_belben
L34OO&Fransgard Winch-pt,C,end - YouTube
This fellow is doing more wood per hp than anyone ive seen with a small tractor and ive put a lot of time into making little things pull big things.   His machine isnt quite as nimble or turn on a dime as a skid steer but this package is i feel pretty comparable in hp and weight of many SS's and still quite woods maneuverable. Hes built an ideal TSI machine for woodlot management.
You will never get a bobcat to flat skid like this because of the short wheelbase.  Whether going forward or back, theyll tip up on the toe or the heel and want to flop.  SS can pull much harder in reverse than in forward unless you have a very heavy attachment on for ballast up front.
 One may move that much wood on a forwarding trailer with a bobcat but only if it doesnt get stuck.  I can do a cord at a time on either machine with the trailer but the 2wd tractor will go where the 4wd skid steer cant in most cases.
Firewood Forwarding with a Bobcat - YouTube
Praise The Lord
Satamax
Well, to illustrate my thoughts.
From 10.30 minutes, he removes a concrete slab with his tracked skid steer.
In my opinion, this is not the tool for the job. A 5 ish ton digger. A hydraulic "hammer"  a bucket. Break the concrete in small clumps. With the hydraulic hammer. Fill the tipper with these. Easier to manage, unload, level etc.
Buying new compact track loaders - YouTube
Over here what he did, wouldn't even happen. Most of the concrete would have rebar grid in it anyway.
Huh, by the way, who tells him that to attach hydraulic quick couplings, he must release the pressure before.  :D
And instead of buying toys, he'd be better to buy a pair of quick coupling for his diggers.
Well, sorry, i like some of his videos. But he drives me mad pushing pins in and out.
alan gage
I think versatility, cost, and size are the reasons skidloaders are so popular here.
With a skidloader I can lift almost anything I need to lift and the machine only weighs about 6000 pounds.
I can move logs.
I can move stacks of lumber.
I can use it to remove dirt and prepare a pad for building a new shop.
I can fit into tight spots (yard around the house)
I can move brush
I can move snow
With attachments I can dig post holes, grind stumps, set trusses, landscape my yard, etc
And I can haul it around with a common 3/4 ton truck and relatively lightweight trailer that keeps me from having to get involved with the DOT.
It's not the perfect machine for most tasks but it can get most of them done. I'm not using it to make money but rather to save time and money by doing more of my projects by myself with less manual labor. It does enough different things that I can afford to justify the purchase. I could not afford buying multiple pieces of more specialized equipment.
There are times when I need to do something the skidloader can't. Then I either hire it done or rent the equipment.
Alan
Satamax
Yes Alan, i understand.
Here untill the nineties, it was backhoe land. Nowadays, you barely see one. Well, there's 3 around me and only one new one, for 7 wheel loaders, 6 or 7 diggers in the 4/7 ton range One wheeled 12 tons, one tracked 16 tons. 6 telehandlers. That's within 100 yards. I'm the ugly duckling with my wheeled crane.
One example, the diggers, there is none without the quick attach. I don't think there is a single professional, who still has a digger without a quick attach.
mike_belben
Comparing swiss army knives with dedicated knives is a good analogy for skid steers.  If you were stranded with only a swiss army knife and no backpack or pockets youd never curse that knife.
But it makes an awful poor machete, filet knife or fighting knife if you have options for those. Skid steer is impressive at many things in a quiver of one.  But sorely lacking at many things in a quiver of many.
Praise The Lord
barbender
Not all skid steers are created equal, either. When you start getting into the larger framed machines the digging, grading, and loading capabilities are in a different league than the small frame units. I prefer to compare my skid loader to my Leatherman😁 Those pliers make it way more handy than a Swiss army knife😊
Walnut Beast
Quote from: Satamax on April 18, 2021, 05:49:02 PM
Wow not a very good example of a guy running a loader 😂. The concrete guys would think this guy is a real idiot
mike_belben
That is definitely true barbender.  Friends large tracked case will spread a fresh triaxle faster than my dozer with a 9ft blade and probably 5k pounds more carriage weight, similar hp.
Praise The Lord
