Author Topic: Did something dumb today.  (Read 133415 times)
Offline Wlmedley
  • Endeavor to persevere
Re: Did something dumb today.
« Reply #2740 on: May 17, 2022, 09:38:43 PM »
Your going to have to take better care of yourself.I still have a lot to learn  :laugh:
Bill Medley WM 126-14hp , Husky372xp ,MF1020 ,Homemade log arch,Yamaha Grizzly 450,GMC2500,Oregon log splitter
Offline Crusarius
  • Lost in....
    • RockModified.com
« Reply #2741 on: May 17, 2022, 10:08:37 PM »
I remember this movie from way back. I think it was called? Bubble boy?? :)
Offline doc henderson
« Reply #2742 on: May 17, 2022, 10:11:45 PM »
It all comes out in the wash!
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #2743 on: May 19, 2022, 08:00:01 PM »
I have no idea how the blade uncoiling did this....but it did.  ::)
Offline Hilltop366
« Reply #2744 on: May 19, 2022, 08:05:17 PM »
You should try sticking a spinning 4½" zip cut wheel under your thumb nail like I did yesterday, it felt great....lucky it didn't get too far.
« Reply #2745 on: May 19, 2022, 08:52:43 PM »
Lynn, if they will cut a tree, they will cut your skin.  better not let Ms. pat see all those.  I got a puncture to my palm once uncoiling a blade.  it rotated right in, and the blade did not seem to feel a thing!   :)
Offline Southside
    • White Oak Meadows
« Reply #2746 on: May 19, 2022, 11:24:13 PM »
That sorcery of coiling bands ought to be ruled Un-Constitutional.   :D  It must be like having the ability to curl your tongue - it's a genetic thing.
Offline Crossroads
  • let’s make some sawdust
    • K Bales Enterprises llc
« Reply #2747 on: May 20, 2022, 12:39:40 AM »
You mean this isn’t normal? I’ve just come to expect leaks when uncoiling bands.  Now I know better 😎
2017 LT40 wide, BMS250 and BMT250,036 stihl, 2001 Dodge 3500 5.9 Cummins, l8000 Ford dump truck, hr16 Terex excavator, Farmi logging winch, Valley je 2x24 edger, Gehl ctl65 skid steer
Offline rjwoelk
    • countrysidefirewood
« Reply #2748 on: May 20, 2022, 01:10:16 AM »
I have no problem coiling up a used band, its the uncoiling I have not mastered. I have watched videos but still have not figured it out.  :embarassed:
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #2749 on: May 20, 2022, 06:20:22 AM »
I have no problem coiling/uncoiling, this was an instance of carelessness I suppose.  I guess there is always a first time.  ::)
Offline firefighter ontheside
  • I like trees.
« Reply #2750 on: May 20, 2022, 07:23:52 AM »
Are you going to have  a new short sleeve shirt now, Lynn?
My blades get uncoiled in my fluffy grass.  I've yet to damage a blade or myself doing it that way.
Woodmizer LT15
Kubota Grand L4200
Stihl 025, MS261 and MS362
2017 F350 Diesel 4WD
Kawasaki Mule 4010
« Reply #2751 on: May 20, 2022, 07:57:43 AM »
the uncoil by hand, is hard/complex.  it seems you have to move from one coil to the next under spring tension.  and the flip needs to be away from you.  gloves are nice but do not stop a puncture.  keep your tetanus up to date.  I have only seen one case in my career.  she was in hospital on a ventilator paralyzed for 2 months, then in rehab for 6 months in Colorado.  Never got back to normal fully.  she was 56 and poked by a rose thorn.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #2752 on: May 20, 2022, 08:02:44 AM »
My then ~16 year old Grandson Luke uncoiling and coiling a blade:
« Reply #2753 on: May 20, 2022, 08:20:06 AM »
Maybe WM can develop a line of safety bands for the elderly sawyer, like safety scissors for pre-K.
       wheeliechair smiley_old_guy :snowball1:
« Reply #2754 on: May 20, 2022, 08:21:11 AM »
If we all just had a Luke!
Offline Dan_Shade
  • I don't want to edit my profile!
    • Shade Custom Sawing
« Reply #2755 on: May 20, 2022, 08:25:45 AM »
@doc henderson how often should one have a tetanus booster?
lots of dull bands and chains
« Reply #2756 on: May 20, 2022, 09:37:17 AM »
It changes if we have a shortage.  with an injury if more than 5 years, or at least every 10 is the schedule I use.  In my office, occasionally I would order it on a patient, and they would refuse.  my nurses knew to just come over and raise my sleeve and give it to me rather than waste it.  It is part of the DPT in children's vaccines.  and the adults get a dedicated booster (boostrix Tdap).  I will check to make sure that is current.  The capitol vs small letters designate the antigen.  so, adults can react to the stronger antigens too much, so the adult version had acellular pertussis "ap" instead of the big P.
Offline Nebraska
« Reply #2758 on: May 20, 2022, 10:21:31 AM »
Thanks Doc.
My blade  un coiling routine  involves tossing it into the hay field by my mill. No rocks or anything out there to dull or dink the blade. It goes sproink and I am the heck away from it. They get shipped flat for resharp.
Offline GAB
« Reply #2759 on: May 20, 2022, 01:11:15 PM »
I suggest trying very hard at making the first time also the last time.
GAB
W-M LT40HDD34 w/6' ext & SLR, JD 420, JD 950w/loader and Woods backhoe, V3507 Fransguard winch, Cordwood Saw, 18' flat bed trailer, and other toys.
i pulled a dumb-dumb...
Started by Dan_Shade on Health and Safety
Last post August 06, 2005, 06:10:46 AM
by sawguy21
How dumb can I be? VERY!
Started by tmbrcruiser on Sawmills and Milling
Last post April 14, 2017, 09:22:37 PM
by Magicman
how dumb can I get???
Started by dnalley on Chainsaws
Last post May 16, 2015, 06:09:35 PM
by JohnG28
Wow, that was dumb...
Started by EmannVB on Sawmills and Milling
Last post December 23, 2010, 05:06:52 AM
by crtreedude
