Welcome, honestly it looks like a lot of work for not much gain. I don't know how hard you have to work to get logs, but there are better ones to be found. You might get a few useable boards off of the sides of the trunk, take a couple slabs and turn the log and see what you get. You might be stuck at home itching for a project, so go for it..... If you get nothing good enough take the milling attachment off of the chainsaw and make some firewood for a back yard fire pit...have a beverage burn some marshmallows and hotdogs.....enjoy an evening. Where are you located?
that not only has spalt init,it has tap hole in it by the looks of it.if it were me,nd i had the tie i would cut it into 8 foot length and cut it around 2.5 thick.see what you have.if you get some nice figured,and tap hole stuff get it stickered and dried.people will pay good money for it as counter top,and table tops.also its warming up,so if your going to do it,it needs to happen fairly soon,as it will start to mold.
Your log is what we call ambrosia maple. Infestation by the ambrosia beetle and the tree’s response to that infection causes the blue green streaks. With every streak is an associated beetle hole. This wood is very desirable. Google ambrosia maple and you will find a lot of info about it.
Started by richhiway on Sawmills and Milling
Started by Ozarkian on Sawmills and Milling
Started by Firebass on Sawmills and Milling
Started by ram70 on Sawmills and Milling
