Author Topic: Sloppy fit of output bearing Sundstrand Hyd. unit  (Read 1507 times)
Offline Jim1934
Re: Sloppy fit of output bearing Sundstrand Hyd. unit
« Reply #20 on: July 30, 2021, 09:45:11 AM »
 I have the complete banjo and axle assy.
I stroked the swash plate actuator.
I have the two hose fittings tied together with a hose. Is this a mistake?
  If lift cyl. and its valve were installed path would be blocked when cyl. at end of travel -correct?
One of the check valves has its ball bearing at the bottom
and I can move the ball against its spring via a rod thur the small hole in the bottom.
The other valve has the ball stuck at the top dead headed and cannot be moved.
There is oil on the valves. My valves do not have push buttons on the top.
Thanks, Jim
Offline mike_belben
  • Pulp Friction
« Reply #21 on: July 30, 2021, 03:06:01 PM »
I dont know what the banjo is.
The hose loop is fine, no you dont need a valve in there.
My cartridge valves are different than yours so i dont really understand what youve got there.  I own a cub with same pump but its 990 miles away or id go llook for you.  Anything that seems stuck in there nedds to be freed up.
My first guess and hope, is the charge pump guts are too dry to lift fluid from the sump at that low rpm. Like those cheap hand crank barrel pumps.  They never lift oil out of a drum until you wet the pump gets, then theyre fine.
 So wet your pump guts. Pull that loop hose and fill it with oil then try again.  If it still wont work, pull one end of the hose and get a pan to catch oil.  Run it and see if you are getting any flow.  I believe the passenger side (US based) fitting is the output.  It comes from the charge pump.  If its not flowing oil your charge pump cant supply your drive pump.
Test that first.
Isaiah 48:10
Online Old Greenhorn
    • Woodsman Forest Products
« Reply #22 on: July 30, 2021, 03:49:40 PM »
I always keep up by reading the 'most recent post' and scrolling through comments like this bring me up short every time and take me down the wrong road until I read a little further in.
 Mike, this is what a banjo looks like:
 As played by one of the best (Bill Keith).
 But perhaps that doesn't make sense to you because it is fully assembled and functional. So to put it in terms you might be more accustomed to, this is also a banjo:
 Sorry, I could not resist. You may now return to your serious technical discussion and I will shut up. :D
Oscar 328 Band Mill, Husky 450, 372 (Clone), Mule 3010, and too many hand tools. :) Retired and trying to make a living to stay that way. NYLT Certified.
OK, maybe I am the woodcutter now.
I can work with wood, but I am NOT a Woodworker, yet.
Offline Jim1934
« Reply #23 on: July 30, 2021, 04:37:19 PM »
When I was a child, 80 years ago, we called the banjo the nearly spherical cast
housing that connects all its internal gears to the inner ends of the two rear axles.
It looks like the round part of a banjo. Today I read case, carrier, rear end, differential.
Thanks for the humor. Jim
Offline mike_belben
  • Pulp Friction
« Reply #24 on: July 30, 2021, 05:43:14 PM »
Gotcha.  Newer slang for that is diff, chunk and pig.
Isaiah 48:10
Offline Jim1934
« Reply #25 on: August 01, 2021, 09:29:27 AM »
Tried all Mike's suggestions with no cigar.
Removed charge pump casting, with shaft vertical,
and it was wet but no oil filled the gap between adjacent gear teeth.
Outer gear 'stuck' to plate below, as one would hope.
Tried rotating casting 180 deg. but did not help.
Small gear is keyed to shaft as it should be.
So now I will change filter, double RPM, and make a sacrifice to the Cub gods.
Thinking about 'warming' stuck valve. Penetrants have not worked. May drill
1/16 hole thru existing hole in top hex nut for punch access.
Doubt if oil viscosity is the culprit.
Thanks to all. Jim.
Offline mike_belben
  • Pulp Friction
« Reply #26 on: August 01, 2021, 09:41:29 AM »
Those big hex cartridges come out for replacement dont they?
If a tow valve is open i think its gonna allow the charge pump flow to bypass the high pressure section.
Were there any valves or check balls inside when you took it apart?  Hydrostatic transmissions have replenishing devices and one way checks to swap out fluid and make it do the right stuff.  Any chance you lost or installed any of that wrong?
Isaiah 48:10
Offline Jim1934
« Reply #27 on: August 01, 2021, 05:53:06 PM »
Trying to upload pix of valves. Spent many hours.
Have had a gallery with pix for a long time.
Trying to add pix to gallery now not working like I think it should.
Service manual states the two are identical. Not mine
On one the ball is held up towards top via a spring.
On other the ball is held down by, apparently, a spring above it.
Tomorrow I will swap locations.
No guarantee these are the correct valves.
I have not modified them. Removed o ring from one in anticipation of heat.
Offline mike_belben
  • Pulp Friction
« Reply #28 on: August 01, 2021, 08:57:11 PM »
I really dont know the answer.
I think i would run the input with a drill and no valve cartridges in place to see if oil is coming up to them.  Thatd atleast tell us if the charge pump is picking up or not.  Maybe spin it both directions.
Isaiah 48:10
Offline Jim1934
« Reply #29 on: August 02, 2021, 09:19:41 PM »
Took valve apart.
There is only one ball.
I am now calling the hex end in pix "down" or "bottom".
R.H. valve is defective. Spring loaded actuating rod in bottom of valve was corroded ,
stuck down, and could never push the ball upward away from its seat. Ball in R.H. pix is
sitting on its seat which is below it.
Short weak spring above ball opposes the other spring.
Will repair and see if that is the solution. Have not tried your, Mike's, last suggestion-yet.
Regards. Jim
Offline Jim1934
« Reply #30 on: August 10, 2021, 12:02:31 PM »
Replaced one valve which was stuck corroded..
Now unit will run but in only one direction. Progress.
Offline mike_belben
  • Pulp Friction
« Reply #31 on: August 10, 2021, 12:57:54 PM »
Swap valve cartridge positions and see if you get a corresponding swapped direction.
Isaiah 48:10
Offline Jim1934
« Reply #32 on: August 10, 2021, 05:12:22 PM »
Would like to but after sitting 4 hours it won't run in either direction.
Thanks for responding.
Offline Jim1934
« Reply #33 on: August 11, 2021, 12:32:54 PM »
Test that first.
Aug 11 Noon.
Did the above a few days ago.
Removed both valves, ran charge pump and oil came out the top of one. Reversed dir of charge pump and oil came out of the other. Wary of the loop to aux. ports. Jim
Offline mike_belben
  • Pulp Friction
« Reply #34 on: August 11, 2021, 04:56:54 PM »
Quote
Aug 11 Noon.
Well thats good news with respect to your charge pump charging and your swash plate swashing.
If this fluid flow from the charge pump to the drive pump can now be directed to a load (the drive motor)  and maintain pressure (by not having any relief cartridge problems that allow leakage back to tank) then you should be in business.
In between the valve positions are some pipe ports facing the sky.  One is the charge pump regulating valve.  Just a little BB or pellet with a spring. Have you been in there?  If one of those is stuck open or pitted real bad the charge flow will have a path to tank and wont pressurize the drive pump.
I believe for the circuit to work you are going to have to take that flow out of the passenger side jic fitting and loop it back into the driver side fitting.  You wont need a hydraulic valve in it.
Isaiah 48:10
Offline Jim1934
« Reply #35 on: August 11, 2021, 08:54:44 PM »
Have not been in those cavities plugged with hex socket heads. Will do so.
Loop (open) always installed. Did try closing it with C clamp but no difference.
To repeat- won't run in either direction regardless of swash plate movement or gear
pump rotation dir.
If that fails I will probably open the two main valves for inspection.
May destroy them buy that is ok. I tried repairing one by soft soldering
bottom can on with a Certainium alloy, 5x strength of normal solder and a
melting point of 420F. I was not careful with alignment but joint was ok.
I am aware of repair services. Thanks, Jim
Offline mike_belben
  • Pulp Friction
« Reply #36 on: August 12, 2021, 08:39:43 PM »
Google this up.
sm2093 (Jul-73).pdf
Its a manual for the JD140 that i have.  My phone is too low on memory to go finding the section but its a big file and should have a good theory of operations abd troubleshooting section on the sunstrand 15 pump
Isaiah 48:10
Offline Jim1934
« Reply #37 on: August 15, 2021, 08:15:20 PM »
Google this up.
sm2093 (Jul-73).pdf
Thanks. Will do so.
Internet been down for four days.
Removed 1/8 pipe plugs and nothing in cavities but oil.
Removed plug with 5/8 hex, also between main valves ,and  it contains a spring and short rod but no ball.
However  it looks obvious that the conical shaped end of the rod rod is pushed into a mating shaped hole by the spring
to accomplish the same thing.
Unit will only run in one direction and then only by one combination of the two main valves.
So far it will only run in one direction of gear pump. CCW looking into pump from normal drive side.
Conclude at least one valve is defective. It will only run when an original valve is nearest the flow
control handle. Used one I purchased is in the other spot. The letter "P" is stamped by valve nearest
flow control lever.
Offline mike_belben
  • Pulp Friction
« Reply #38 on: August 15, 2021, 08:34:47 PM »
Without having known good cartridge relief valves, its hard to say whether they are the issue or something inside didnt go back together right.  Ive never been in one and cant be of any help there.  But i hope that manual has something inside thatll help.
The spring and little plug valve should be doing the same thing.. I cant honestly remember if mine was a BB or something else.  I know i had to try many springs in mine to add on the aux high pressure pump fed by the charge pump.  I kept blowing out the front seal on the addon pump, until i got that circuit down to about 10psi with a pen spring.  Nothing to do with your setup.  You want 500-700 i that circuit if i remember right.
The empty ports are for pressure gauges.  A good next step for you in my opinion.
Isaiah 48:10
Sloppy day
Last post January 31, 2021, 11:42:37 AM
by Andries
Sloppy weather
Started by Patrick NC on General Board
Last post February 07, 2021, 07:28:59 PM
by hopm
Fixing sloppy joinery
Started by TFwannabe on Timber Framing/Log construction
Last post September 20, 2018, 01:01:27 PM
by Jim_Rogers
Sloppy yoke or runny eggs?
Started by sandersen on Forestry and Logging
Last post March 24, 2017, 06:53:15 PM
by sandersen
