362CM full skip 28”
Started by snonut12, September 26, 2021, 09:25:30 PM
snonut12
I currently have a Stihl MS362CM with 22" bar (36RS76) which I've found to be a happy medium between the 20" and 25". However I've occasionally run into a few bigger stuff where 28" bar would be more helpful. Can my saw pull this with a full skip chain and oiler cranked all the way up? It would be used on box elder and ash that are slowly rotting as well as some pine/spruce.
lxskllr
I'd be most worried about the oiling, especially in dry dusty ash, but it should pull the chain ok.
Gary Davis
i have had a 28 on my 360 and it would work,  just kept the rpms up and it will should be ok .I had a 390 that came with a 28 in bar
