Amputated
Started by Nebraska, May 14, 2024, 04:29:57 PM
Nebraska
Predator amputation completed.....transplant to follow.
rusticretreater
talk about your click-bait!
Kubota BX25
Homemade Log Arch
Husqvarna 562xp
doc henderson
be sure to keep it on ice till you are ready! ffcheesy
SawyerTed
Amputated vs Excised
I clicked on amputated while excised probably would make me think taxes and pith me off.
Hope the graft takes and there's no required ongoing anti rejection therapy required.
Andries
How close was the tissue match for the donor ?
Will it be flown in from off-shore or is it from somewhere local?
If you have choice, can you get one that's a bit bigger?
It's been said that bigger is better.
LT40G25
Ford 545D loader
Stihl chainsaws
SawyerTed
Now you're talking augmentation!  ffcheesy
Resonator
Read the title and thought this was gonna be on "Health and Safety"...  ffsmiley
Nebraska
I'm just hoping the holes line up.   ffsmiley
Nebraska
Went with an on shore donor, similar in strength. No augmentation.
Old Greenhorn
You surgical guys always throwing around the big words. ffcheesy
 Now you have to complete the transplant and hope the organ sizes are compatible and the blood types match. Good Luck Doc.
jpassardi
What are you replacing it with? I upgraded from a 15 Kohler to a 25 Kohler and it's like a different mill.
Nebraska
Dodging rainstorms and waiting for a young man to get done with finals to help me put it on. (I don't need his help really...I just want him to learn a little)
Dad thing. Then I will reveal the tissue type.  ffcheesy
doc henderson
good luck to the transplant team!
Nebraska
First muffler wouldn't clear the frame on the mill. Plan B initiated  Then had to, cut and bale some hay, clean, grease, and put up my hay equipment, hung some dry wall, my father survived a heart attack, and is doing well. Life happened, so working back around to the sawmill. I bought some bare flanges and pipe.  Did a little welding last night. If the phone is gentle I will try and have something picture worthy this evening.
Nebraska
Andries
I see the headers, and they look fine.
Not too long and sized to provide clearance.
However, the muffler is going to have a tissue rejection complication.
The headers are threaded and male. The muffler is Bolton.
I'm not sure if this surgery has been planned out as well as doc hoped?
LT40G25
Ford 545D loader
Stihl chainsaws
Southside
Aint nothing a little JB weld won't fix.
White Oak Meadows
Nebraska
Removed excess tissues from the predator, it had two round individual mufflers. They cleared the frame. Motor mount bolt pattern doesn't line up. So trying to figure out a good way to mark the holes in the base plate of the motor on a piece of plywood to make a marking /drilling guide. I can't seem to find a template file on line.
doc henderson
are the "headers" threaded into the motor or do I see a couple cap bolts holding them in.  You can weld to that pipe if the back end is bolted on.  On My log splitter I was able to adapt to thin tubing and make a remote car muffler application.
WV Sawmiller
   In line with the early parts of this thread:
A man went to his doctor with chest pains and was informed he'd have to have a heart transplant but he was lucky as they had a new shipment. He showed them and explained the costs. Here's the first - its from a 20 y/o Olympic swimmer and costs $50K. Here's the second from a 60 y/o man who smoked and drank and its only $20K. Here's one from a 40 y/o lawyer who did not smoke or drink and it is $250K." The patient asked "Why is the third one so much more expensive?" His doctor replied "Because its never been used."
Nebraska
Made a template and drilled holes hopefully the transplant will progress soon.
Andries
That looks like a good Shadetree mechanic hard at work. :thumbsup:
LT40G25
Ford 545D loader
Stihl chainsaws
Nebraska
I in no way resemble the above choice of the  adjective "good" in reference to my mechanical skill as suggested by Andries.
Half fast is probably better term.  I now at least have a chance at it bolting up. Marking the holes accurately was a challenge. There was no clearance to trace.  I first held broken pencil lead in my leatherman at 90 degrees  and tried to trace them but it wasn't good enough so I tried come up with different but everything else would bleed under the hole.  Then i saw a can I had a can of spray graphite and fogged over the holes and it left enough of a mark to get a good shot.  It won't hurt the engine base and was good enough.
Ljohnsaw
That's a lot of holes...
John Sawicky
SkyTrak 9038
Ford 545D FEL
Genie S45
Davis Little Monster backhoe
Case 16+4 Trencher
Nebraska
I didn't drill them all through them plate as there were some overlap partial holes from the Predator motors pattern.  There is four good ones though.
