Well, i went mad.
Started by Satamax, July 30, 2020, 03:17:28 PM
Satamax
mike_belben
Those are my favorite issues.  Dont ask dont tell
Praise The Lord
Satamax
Found something to be a bit more mobile. Than the 144 KW  Volvo gen set.
Satamax
Guys, it's a ford 6 cylinder. At the end of the head, opposite the fan, there is a 8000 with some unidentified markings, for the moment. It was nearly dusk when we got back.
mike_belben
Ford dover / dorset boat and tractor engines from the 60s.
Praise The Lord
Satamax
Satamax
Weighted it today. Ouch! 1300KG, 2860 pounds.
I will need to sort get a crane which can take that.  :-\
Satamax
The happy dance says it all!!!
Satamax
I'm behind the gen set.
Remi was uncomfortable, starting the thing with my knife between two lugs of the keyswitch.
And Dri was not confident either. Look how they put some distance between themselves and the engine when it starts.
Anyway, if anybody knows, or has an idea on how to clean the chassis tank, at the bottom, under the engine. It's full of water for the moment. I started with a jerrycan, which has stubs for linking the fuel lines.
Next step, straighten the radiator, and see if it holds coolant.
Satamax
Better video.
Dorset generator set running. - YouTube
Water holds In the cooling circuit. Tank is empty.
Diesel filter head Is pissing from the pump.
I need to clean the whole thing.
Find a regulator of one kind or the other. As it is missing.
Find a key.
Tacotodd
Max, siphon it completely dry (as best that you can) and start all over.
That's MY suggestion.
Trying harder everyday.
Satamax
Tacotodd, you mean diesel circuit? It is all fresh diesel. Not from a tank, but from a jerrycan. A bit like you use on a boat. Tank has been emptied from the water today. I need to clean it. And check with an endoscopic camera. Find an exhaust.  And many other things.
mike_belben
Thats a really good exhaust manifold design.  Better than most today
Praise The Lord
Satamax
Yes mike, but not really neighbor compliant.  ;D
