Author Topic: Makita KP312 Helical Cutter Head Conversion  (Read 399 times)
Offline mattgancz
« on: March 30, 2021, 02:36:05 PM »
Greetings Forestry Forum:
I am looking to upgrade a Makita KP312 planer with a helical cutter head, but the following comment from Shelix Heads gives me pause:
IMPORTANT: The outfeed table on the Makita KP-312 is not adjustable in height and neither are the insert knives on the SHELIX head. Therefore, the SHELIX head diameter has to match exactly the cutting diameter of the original head. Unfortunately, Makita has its own tolerances with the assembly of the machine where the space between the center of the cutter head to the surface of the outfeed table may differ on some machines. The cutting diameter of the SHELIX head equals the cutting diameter of the original head as we found on most machines. This diameter is 2.047". Before ordering this SHELIX Head, you need to measure the cutting diameter of your original head to see if it is the same. If it is different, you will need to decide whether or not you are able to customize the outfeed table to align it with the SHELIX head. (Cutting diameter = the measurement from the tips of properly set new blades not the body diameter)
The cutting diameter on the machine in question is 2.053Ē.  Does anyone have experience with this issue, and can speak to it?
Shelix does not have an easy return policy; there seems to be another company, Sheartak.  Does anyone have experience with them?
The benefits of the upgrade are reasonable on paper, but there are no reviews from either of these companies on this helical cutter head.  Any help from those with experience would be appreciated!
Offline Edvantage
Re: Makita KP312 Helical Cutter Head Conversion
« Reply #1 on: April 02, 2021, 12:03:14 PM »
.006 difference in diameter would translate to .003 different from table height. I doubt you would notice it. Probably within original factory tolerance.
Offline Hilltop366
« Reply #2 on: April 02, 2021, 12:58:31 PM »
If I have this right in my head the new shelix is going to be slightly smaller. If it was a issue perhaps the out-feed could be lapped or surface ground a tiny bit to make it line up properly?
Offline cib
« Reply #3 on: April 04, 2021, 11:02:23 AM »
To put this in perspective this is the thickness of a human hair.
Offline Edvantage
« Reply #4 on: April 04, 2021, 03:59:43 PM »
Coarse hair at that. Fine hair is .002  really the error is splitting hairs.
Woodmaster Planer 725 with helical head
Started by gginseng4 on Drying and Processing
Last post March 25, 2019, 03:16:03 PM
by gginseng4
Makita 3803A groove cutter
Started by stenger on Timber Framing/Log construction
Last post January 29, 2008, 05:03:36 PM
by stenger
spiral cutter head?
Started by shad on Drying and Processing
Last post October 11, 2010, 01:55:28 PM
by shad
Old Hydro-Ax 520 with 8' cutter head
Started by john_bud on Forestry and Logging
Last post December 22, 2007, 02:02:25 PM
by Gary_C
