Author Topic: Pine tar wood preservative  (Read 252 times)
Offline dfvellone
« on: May 13, 2021, 01:25:44 PM »
Anyone familiar with pine tar outdoor wood preservative? The forumulations I'm seeing are a mix of pine tar and raw linseed oil.
Any experience with it you can share would be appreciated.
Thanks, Dan
Offline DonW
Re: Pine tar wood preservative
« Reply #1 on: May 13, 2021, 03:32:50 PM »
Yes, I've used pine tar for years, tarring my barn and some places inside the barn and other buildings, treating rope and just about anywhere I can use it I do, more because I like the process  than for preservation. And with this use I've found that it cannot tolerate uv light so unless you are prepared to re-coat an exterior twice yearly an addition of pigment is needed along with the raw linseed oil. Also, it's very viscous and needs to be applied hot, (preferred ), or thinned. Tarring rope I use old chainsaw fuel, diesel's probably better, and dilute heavily. It takes weeks to oxidize typically which needs to be kept in mind in cases where it comes in contact, particularly with a dog that's prone to sheading.
Hjartum yxa, nothing less than breitbeil/bandhacke combo.
Offline DonW
« Reply #2 on: May 13, 2021, 04:14:33 PM »
I see, df, you've posted up an almost identical query about a year ago. Unsatisfactory responses?
Online btulloh
« Reply #3 on: May 13, 2021, 04:31:13 PM »
Look up pine tar kilns. Thatís the way they used to do it for shipbuilding and waterproofing. It can be done on a small scale. Uses a retort type of approach. Itís also in vogue now with off-grid and primitive method people. Probably been an article in mother earth news at some point.
HM126
Offline Tom King
    • HistoricHousePreservation
« Reply #4 on: May 13, 2021, 04:48:33 PM »
Before the Revolution, Naval Stores was one of the largest exports from North Carolina.
Naval stores - Wikipedia
Offline DonW
« Reply #5 on: May 13, 2021, 09:46:00 PM »
Some years back making pine tar.
https://archive.org/details/WoodTarMakin
Pine Tar preservative?
Started by dfvellone on Timber Framing/Log construction
Last post July 16, 2020, 08:21:28 AM
by Nebraska
Valhalco Wood Preservative
Started by chet on Drying and Processing
Last post July 16, 2009, 06:07:42 AM
by kelLOGg
Flammable wood preservative?
Started by sawguy21 on Health and Safety
Last post April 12, 2007, 08:47:08 PM
by Tom
Using copper sulfate for wood preservative?
Started by mjeselskis on Sawmills and Milling
Last post April 02, 2012, 08:52:01 AM
by bandmiller2
