Author Topic: New car oil change  (Read 379 times)
Offline moodnacreek
  • Sawin by the notches
New car oil change
« on: September 20, 2021, 01:06:39 PM »
Changed the oil in our 'new' 2012 Honda civic yesterday. Had to hammer a 6 point to get the oil plug out but the threads where still there. The no name oil filter was falling off. But whoever did it last time was smarter than me because I can't reset the maintenance light. Book says has to go to dealer. That light could be on for a long time, Honda dealers around here will stick it..... I better stop right there.
Offline sawguy21
Re: New car oil change
« Reply #1 on: September 20, 2021, 01:08:46 PM »
That is what electrical tape is for. ;D
Offline alan gage
« Reply #2 on: September 20, 2021, 01:20:03 PM »
Shouldn't require the dealer. Check youtube, which is what I do when our service information fails.
Alan
Online btulloh
« Reply #3 on: September 20, 2021, 01:25:04 PM »
Get an OBD2 reader. That will let you reset the light, as well as read codes.  Bluetooth version is probably the best value and more capabilities.  Look up OBDLink MX+ or similar.
Another option is go to Autozone or similar auto parts store. They will read codes and reset for free.
HM126
Offline VB-Milling
  • Always learning
« Reply #4 on: September 20, 2021, 01:41:20 PM »
https://www.instructables.com/How-to-Reset-Oil-Life-Honda-Civic-2012-2015/
1. Turn the ignition to run (one position before starting engine).
2. Use the controls on the left hand side of the steering wheel. Press Menu and go to the Vehicle Menu screen.
3. Select Vehicle Information with the (+) button, then press the SOURCE button.
4. Press the SOURCE button again to go to the Maintenance info screen. The engine oil life appears on the i-MID.
5. Select Yes with the (-) button, then press the SOURCE button
6. Turn the ignition off and then start the engine to verify the indicator has been reset
Online Tom King
    • HistoricHousePreservation
« Reply #5 on: September 20, 2021, 03:30:52 PM »
A friend of mine had to change the oil pan on his Subaru because whoever put the drain plug in over-torqued it so much that there was no way to get it out. He had two different mechanics try to get the plug out.  The plug has a small head for the size of the threads.
My Wife has the same model, so the last time I changed the oil, I also changed the drain plug to a Fumoto valve.
Not only does the plug have a small head, but it's up in a recess in the pan.  The Fumoto valve is well protected up in there.  I need a particular pair of pliers to pull the little lever down, and rotate it, but I already had those.
I like that valve.  You can slide a piece of hose over the outlet, and not get a drop of oil on anything when you drain it.
Offline moodnacreek
« Reply #6 on: September 20, 2021, 08:16:11 PM »
How to Reset Oil Life: Honda Civic 2012-2015 : 7 Steps - Instructables
Thanks, VB
Change band brands...change tracking?
Started by kelLOGg on Sawmills and Milling
Last post July 21, 2014, 05:56:28 PM
by ladylake
How do you change a bar tip
Started by parrisw on Chainsaws
Last post March 13, 2006, 01:40:45 AM
by parrisw
change name
Started by donny hochstetler on Technical Support Topics
Last post July 07, 2008, 04:31:39 PM
by Riles
thumbup
A change for the better
Started by John Fish on Chainsaws
Last post May 16, 2013, 10:24:57 PM
by AdkStihl
