Mist if the time I spent chasing free logs, or cut em and you can have em type of logs ended up being a waste of time. I guess I had more energy back then😁 The logs I make money on are the ones I bought from loggers. Even though they seem expensive, buying exactly the logs you need saves you from wasting a ton of time. I would suggest reaching out to a logging outfit. Tell them what you're looking for, and given your distance from the loggers, I'd offer to pay for the wood up front. I would go over and meet them when they load it to make sure you're getting what you asked for, and have a big envelope of green to pay for it right there. The reason is that no one is going to risk sending a load that far and not get paid for it. The trucking costs are going to be huge for a haul of that distance. Once you get someone to bite, then you can start forming a relationship with that logger. If they can get paid, get in and out, basically make money with no drama, they will likely continue to bring you wood. My boss (I work for a logger) doesn't like to mess around at all, but we have a mill 2.5 hours away we will bring wood to. It's an Amish mill that buys good grade hardwood logs from us. Now, we shove load after load of hardwood logs into the local pallet mills, and we don't have any close grade mills. I cringe at the beautiful hardwood logs that go to the pallet mill. But the Amish pay enough to make it worth our while to sort the good logs (probably almost twice the $$) so when they call looking for logs, we try to supply them. We would do the same for you if you were in our area, if you paid upfront.
He's got a 20' over 40" dbh pecan log
Started by Patrick1128 on Urban and Community Forestry
Started by RussMaGuss on Sawmills and Milling
Started by chet on Forestry and Logging
Started by Brad_bb on Forestry and Logging
