Author Topic: Jim's Timber Frame Design Services  (Read 24019 times)
Online Jim_Rogers
  • Keep your chisels sharp.
    • jrsawmill.com
« on: August 02, 2003, 12:59:38 PM »
Jim Rogers Sawmill has acquired new state of the art CAD drawing programs that can make 3d drawings of timber frames for sheds, cabins, barns and houses. Detailed elevations and shop drawings for each piece are available.
All inquires welcome.
Located in Georgetown, Ma 01833
1-800-422-6250
www.jrsawmill.com
http://jrsawmill.com/JimRogersTimberDesigns.htm
Added 1-23-2013 This is a part time business. I do not draw full time.
Online Jim_Rogers
    • jrsawmill.com
Re: Jim's Timber Frame Design Services
« Reply #1 on: September 23, 2009, 09:00:35 AM »
Sample pdf drawings available upon request.
Online Jim_Rogers
    • jrsawmill.com
« Reply #2 on: June 22, 2012, 05:24:29 PM »
Recently I completed several frame drawings for Forestry Forum members.
Here is a shot of a two car garage and woodworking shop with outside sawmill roof for a member in WI:
And here is just the frame:
If you'd like a quote for a set of plans for your project send me an email or give me a call.
Jim Rogers Timber Designs.
Offline Jeff
  • Fearless Leader
  • Oh la di oh la da
    • Behind the  Forestry Forum YouTube channel
« Reply #3 on: June 22, 2012, 05:27:24 PM »
What's the footprint on that one Jim?
Online Jim_Rogers
    • jrsawmill.com
« Reply #4 on: June 22, 2012, 05:31:41 PM »
The garage had a limit by the town to be only a certain per cent of the house size.
So to get it right it came out 21' 1" wide by 31' 1" long.
The outside roof for the sawmill is 26' long and stick out 8' beyond the walls which will be 2x6 outside the frame for insulation.
Thanks for asking.
Jim Rogers
Offline Jeff
  • Fearless Leader
  • Oh la di oh la da
« Reply #5 on: June 22, 2012, 05:41:14 PM »
What is the skill level needed for something like that?
Online Jim_Rogers
    • jrsawmill.com
« Reply #6 on: June 22, 2012, 05:44:59 PM »
Well it is a timber frame building and you need to know how to cut joints and erect the frame using mortise and tenon joints being held in place by pegs.
It is not a stick built thing.
I can draw a stick build one if you want one.
Jim Rogers
Online Jim_Rogers
    • jrsawmill.com
« Reply #7 on: June 22, 2012, 05:51:06 PM »
Here is another frame for a sawmill shed building. No walls on the sides or either end.
The green block is my 3D arrow pointing north.
And here is a shot of the frame only:
This frame is 24' x 30' with 11' high plates on the sides.
Posts are oak, rafters are either cottonwood or ash. Gable end boards are cottonwood.
To be built in souther MI.
Jim Rogers
Online Jim_Rogers
    • jrsawmill.com
« Reply #8 on: July 24, 2012, 12:41:48 PM »
My latest frame design for a FF member.
This is a 16' x 24' Pool Screen house to be built in Atlanta, GA.
Let me turn your ideas into plans so you can cut your own frame.....
Contact Jim Rogers email address in my profile, or call number in first post above.
Jim Rogers
Offline beenthere
« Reply #9 on: July 24, 2012, 12:48:40 PM »
Looks great.
I would add some overhang on the gable ends to better deflect the water from getting at the siding. But that may just be me. ;)
Online Jim_Rogers
    • jrsawmill.com
« Reply #10 on: July 24, 2012, 12:51:44 PM »
The roof deck board can be extended some. I'll pass that on to the customer.
Thanks for the tip.
Jim Rogers
Online Jim_Rogers
    • jrsawmill.com
« Reply #11 on: September 10, 2012, 01:54:14 PM »
I recently received payment for another timber frame design I did for a Forestry Forum member.
Here is his bridge rail design:
Jim Rogers
Let me get your ideas out of your head and down on paper for all to see......
Contact Jim Rogers at jrsawmill (at) verizon (dot) net
Offline scsmith42
    • Whispering Pines Farm
« Reply #12 on: September 10, 2012, 04:42:31 PM »
Jim Rogers
Jim, is the above-deck portion of this bridge structural, or just aesthetic?
Tom's 3638D Baker band mill
Online Jim_Rogers
    • jrsawmill.com
« Reply #13 on: September 10, 2012, 06:24:18 PM »
There was more to the deck then I drew.
I was hired only to do the railing design.
He gave me the outside dimensions of the "D" shaped logs and the deck dimensions.
He did the base logs and decking himself.
Online Jim_Rogers
    • jrsawmill.com
« Reply #14 on: December 09, 2012, 10:44:52 AM »
Check out this link for a set of plans to build a 12' x 16' shed with two doors in the FF for sale section:
https://forestryforum.com/board/index.php/topic,62408.0.html
Jim Rogers
Offline in10sity
« Reply #15 on: December 11, 2012, 07:04:37 PM »
Hello Jim,
Just curious how my plans are comming.  Was the deposit sufficient.  Do I need to rethink my design. Any issue using the timberlinx connectors. Haven't heard much siince I sent a deposit through paypal.
Thanks,
Gary
Online Jim_Rogers
    • jrsawmill.com
« Reply #16 on: December 11, 2012, 07:14:28 PM »
Sorry for the delay in responding to your last email.
I'll send you something in a few minutes.
Jim Rogers
Online Jim_Rogers
    • jrsawmill.com
« Reply #17 on: December 13, 2012, 06:53:17 PM »
Here is another finished drawing of a huge bent to be used as an entry way to a "fitness center" in Alaska:
Just another one of the many types of projects that I can help you with.
Jim Rogers
Offline brendonv
  • Arborist
    • www.VorioTree.com
« Reply #18 on: September 24, 2013, 07:49:59 PM »
Just wanted to bump.
I bought two plans from jim recently, one stock plan, and one custom plan to house two large trucks.
Plans came through fast, clear, and jim answered any dumb questions a new guy can have.
Thanks again for the services
"Trees live a secret life only revealed to those that climb them"
www.VorioTree.com
https://www.facebook.com/pages/Vorio-Tree-Experts-LLC/598083593556636
Online Jim_Rogers
    • jrsawmill.com
« Reply #19 on: August 13, 2016, 02:54:46 PM »
I recently helped a client with milling his own logs for his design of a screen porch.
And then I taught him how to cut the joints to erect his frame.
Yesterday, with a crane, they erected the frame.
Frame erected:
It's nice to see your design complete and standing.
If you'd like to get a set of plans from me, let me know and I'll do my best to help you.
Jim Rogers
Timber Designs
Timber size calculator and timber frame design.
Started by Joe Vachon on Timber Framing/Log construction
Last post July 07, 2017, 10:25:46 PM
by Roger Nair
German Timber Frame Design
Started by maineframer on Timber Framing/Log construction
Last post March 03, 2007, 07:01:48 PM
by Dave Shepard
Timber frame + straw bale design help
Started by Slablord on Timber Framing/Log construction
Last post August 28, 2020, 05:52:10 AM
by thecfarm
Timber frame design, traditional vs actual.
Started by Upstatewoodchuc on Timber Framing/Log construction
Last post November 11, 2019, 11:37:43 AM
by Brad_bb
