sorry, but i'm with ADK on this as well, the 10mm's are gettin hard to come by.............
Quote from: old 030 on May 13, 2013, 04:50:01 AMsorry, but i'm with ADK on this as well, the 10mm's are gettin hard to come by............. I have an 044 but no idea if its a 10mm, is there a easy way to know without opening it up?
Quote from: gspren on May 13, 2013, 06:55:58 PMQuote from: old 030 on May 13, 2013, 04:50:01 AMsorry, but i'm with ADK on this as well, the 10mm's are gettin hard to come by............. I have an 044 but no idea if its a 10mm, is there a easy way to know without opening it up?It will have a serial # before 29 382 283.
You might want to check that #. This is the number.... #129583701
Exactly where is the SN at on an 044? And which is better the 10mm or 12mm?
Quote from: gspren on May 15, 2013, 01:39:05 PM Exactly where is the SN at on an 044? And which is better the 10mm or 12mm?The Ser# number is stamped on the case whereabouts the exhaust exits the muffler...toward the front of the saw....above the clutch cover.....on the left hand side. The 10mm saws run better. (Image hidden from quote, click to view.)
Does the plate holding the bar on or the muffler need removed? It seems funny that I have used this for well over 15 years and never looked for a serial number.
If the tradee and the trader are happy that's all that matters .
Started by kelLOGg on Sawmills and Milling
Started by moodnacreek on General Board
Started by donny hochstetler on Technical Support Topics
Started by parrisw on Chainsaws
