Author Topic: New member, thanks  (Read 507 times)
Offline Colin52
New member, thanks
« on: April 10, 2021, 11:14:49 PM »
Hey fellas, I usually find my way to reading threads on here looking for how to do certain things, so I figured I would sign up and be able to ask questions and share photos.
Currently homesteading on 80 odd acres in the ozarks.  Main project right now is a piece en piece building, starting with a goat shed, then a storage shed, then something larger if that goes well.  I have a lot of trees, some are even straight, but not many really large ones.  Property was selectively logged for those.  I figure the piece en piece will allow me to find enough usable timber in small lengths.  Another main reason is it will be much easier to haul short and somewhat lighter hewed pieces through my hilly woods, filled with boulders and lots of edge rock and creeks.
I figure to need advice from time to time, but for now I just wanted to introduce myself.
I have a few years to build several buildings, pathways, and some fun pieces like gazebos and pergolas.  I have alot of hand tools, and two tempermental chainsaws that haven't ended up in the creek yet, but may not last the week.  I've made some mortice and tenon joints of good size for small animal buildings, hewed beams and built doors, but still pretty new to forestry and carpentry.  I've cut down lots of trees in the past working on a farm, and clearing out blowdowns from grass fields in oregon, but these were usually oak and I'm trying to get the hang of tree identification.
Thanks to all for all the good advice and tips I've already gotten on here.  I hope to have projects to share from time to time, probably some that turned out well and some that might be worth a chuckle or two.
Offline LIL
  • Gender: Female
  • Mini Offloader!
Re: New member, thanks
« Reply #1 on: April 11, 2021, 03:08:57 AM »
Guess you know already to stop and sit a while.  The others will be along shortly to say hi and welcome you I'm sure.
Welcome to the FF
LIL
Hobbies and Interests
Interests revolve around my partners love of sawmills! - Hence being his NUMBER ONE OFFLOADER - Myself - I like the smell of sawdust. If I had my choice I would have BIG MACHINERY - who wouldnt want would their own combine harvester and an 18 wheeler (Scania)
Online HemlockKing
« Reply #2 on: April 11, 2021, 06:13:38 AM »
Colin, welcome to the forestry forum of good comradery!
Nothing worth having comes without a fight, gotta kick at the darkness til it bleeds daylight
Offline dgdrls
  • Learning the Art of Milling Logs
« Reply #3 on: April 11, 2021, 07:38:42 AM »
Warm welcome Colin52,
D
Online Don P
    • Calculator Index
« Reply #4 on: April 11, 2021, 07:57:57 AM »
Cool, looking to see how it turns out. We need to move some old log barn logs out of the new(er) barn at work and have thought about recycling them into a 3 sided piece en piece blacksmith shop.
The future is a foreign country, they will do things differently there - Simon Winchester
Online Texas Ranger
  • Texan, by God and by choice.
« Reply #5 on: April 11, 2021, 09:16:49 AM »
Welcome from Texas, although I am an old Ozark boy myself.
Offline Colin52
« Reply #6 on: April 11, 2021, 09:58:34 PM »
Thanks everybody!
Is there a good way to tell if a chainsaw has been overheated?  Asking for a friend...
Offline samandothers
« Reply #7 on: April 12, 2021, 08:15:19 AM »
Welcome sir!  Look forward to your adventures and the build.  I can't help on the saw question. Good luck with the cranky or maybe 'un-cranky' saws.
Offline Colin52
« Reply #8 on: April 12, 2021, 08:04:38 PM »
Thanks, I'm going to need it.  Its a husqvarna 365, and it just doesn't seem as powerful as I was expecting.
Offline Stephen1
  • Where there is a will, there is a way!
    • muskoka Sawmill
« Reply #9 on: April 12, 2021, 08:50:46 PM »
Welcome to the FF.
It would be great if you fill out your info , so when you post , it helps others answer your questions as they understand your equipment and location.
Cheers
Online Tacotodd
  • To learn and help
« Reply #10 on: April 12, 2021, 10:48:45 PM »
What are you doing with the 365 that might make it not powerful enough? If youre using it to mill, then thats another life all its own! The size of the lumber for milling is limited.
What is the other saw? Im wondering if its somehow just a tune issue.
Just sayin...
Trying harder everyday.
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #11 on: April 17, 2021, 11:26:54 AM »
Welcome to the Forestry Forum, Colin52!
~Chuck~
Retired USAF 1989, Retired School Bus Driver 2012, now semi-retired Mobile Sawyer, 2018 Silverado 4X4
1995 Wood-Mizer LT40HDG25 Kohler - Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
Online Hilltop366
« Reply #12 on: April 17, 2021, 11:55:42 AM »
Greetings from Nova Scotia.
You can do a compression test on the saw and remove the muffler to check the piston for signs of over heating.
Lots of other things can effect the power output, dirty air filter, fuel filter, muffler screen, air leaks, carb adjust.....
Offline firefighter ontheside
  • I like trees.
« Reply #13 on: April 17, 2021, 10:05:22 PM »
Welcome aboard Colin.  I'm about 30 miles south of St Louis.
Woodmizer LT15
Kubota Grand L4200
Stihl 025 and MS291
2017 F350 Diesel 4WD
Kawasaki Mule 4010
Offline Patrick NC
  • I'm not new anymore, but still pretty green
« Reply #14 on: April 18, 2021, 05:50:47 AM »
Welcome to the forum. Best cure for a saw that doesn't seem powerful enough is buy a bigger one!😁
Norwood HD36, Husky 372xp xtorq, 550xp mk2 , 460 rancher, Kubota l2501, Case 1845 skid steer,
Howdy, new member here, old AS member with questions
Started by Hillbilly Rick on Chainsaws
Last post November 06, 2013, 03:04:03 PM
by Hillbilly Rick
member, full member???
Started by Dave_Fullmer on General Board
Last post November 27, 2003, 10:26:18 AM
by etat
New Member
Started by brent smith on Drying and Processing
Last post December 11, 2013, 04:13:45 PM
by Sixacresand
A New Member> Thanks For Being Here
Started by Wintergreen Mountain on Sawmills and Milling
Last post March 04, 2010, 12:07:32 PM
by Don K
