Author Topic: 3 phase 240/416 military surplus 15k generator  (Read 364 times)
Offline Sedgehammer
  • Old enough to know better, but ya only live once!
« on: April 13, 2021, 11:54:49 AM »
Question is - Can I run 2 phase 220 - 240 on the 2 legs and just ignore the third leg?
Offline sawguy21
Re: 3 phase 240/416 military surplus 15k generator
« Reply #1 on: April 13, 2021, 02:39:46 PM »
I think you mean single phase which is most common, 2 ph is obsolete. Frequency becomes a problem, there are members here much more familiar than I.
Offline Sedgehammer
« Reply #2 on: April 13, 2021, 02:53:29 PM »
Yes, correct. single phase. thanks
Offline mike_belben
  • Pulp Friction
« Reply #3 on: April 13, 2021, 02:56:40 PM »
Yes.  Sawguy is right thats 230VAC 1PH.
You will have an "unbalanced load"  on the alternator by the unused winding.. but for whatever youre doing i bet its inconsequential.
Look up "split phase electric power" to learn a bit more.  I am thinking your two phases will be 120* apart relative to neutral where split phase is 180* out of phase leg per leg.
But yeah.  Two 120VAC legs of a 4wire 3ph 230VAC system will run 220v 1ph junk every single time i have ever tried it which is quite a few now.  No smokeshows yet.
Measure the leg voltages.. Beware of 277vac aka "highleg"
Psalm 37:16
Offline Gary_C
  • Sunrise on the Prairie
« Reply #4 on: April 13, 2021, 03:59:26 PM »
Not a good idea at all to use two phases of the three to substitute for single phase. I don't know exactly what it will do but you will certainly have some strange things going on. As Mike said the two phases will be 120 degrees out of phase instead of 180 degrees. So your phase to phase voltage will not be correct and meters will not measure the correct voltages because they measure RMS or root mean squared voltages which will give you different readings with two points 120 degrees out of phase. I suspect the most damage will be done to sensitive electronics. Also there is the question of is the generator delta or Y connected. What you are doing is risky so consider the cost of a failure before you decide.
Offline Southside
    • White Oak Meadows
« Reply #5 on: April 13, 2021, 04:07:54 PM »
If it's a 12 wire alternator you should be able to change the taps to 240V single phase or, you could pick up a dry transformer and have clean voltage.
White Oak Meadows
Offline mike_belben
  • Pulp Friction
« Reply #6 on: April 13, 2021, 11:12:23 PM »
I wouldnt try it on my EKG or space shuttle comms set, but ive done it for a jetwash, a welder, heater elements, pumps, and a sunnen hone which is just an electric motor really.
Psalm 37:16
Offline Ed_K
« Reply #7 on: April 14, 2021, 07:57:59 AM »
 On a 220 single phase welder cable can I hook to one leg and the neutral wires and get 110 volts without ruining a 110 volt motor?
Ed K
Offline mike_belben
  • Pulp Friction
« Reply #8 on: April 14, 2021, 08:27:55 AM »
Yes but you should also have an independant ground wire so that if the neutral is lost the conduit and motor housing doesnt become energized.
Psalm 37:16
Offline Sedgehammer
« Reply #9 on: April 14, 2021, 08:30:19 AM »
I did a bit more research and if just a motor running it wood prolly be ok, but as you said sensitive or load changing it woodn't be good. I found a vid that shows exactly how to convert it and change the instrumentation to also work.
Thanks everyone
Offline mike_belben
  • Pulp Friction
« Reply #10 on: April 14, 2021, 10:47:42 AM »
Glad to hear it.
disclaimer:  i am not a licensed electrician and have just enough experience to be dangerous.  Please do not risk your life, liberty or property on anything ive said in this thread, and do consult with a pro before proceeding.
Psalm 37:16
Offline Sedgehammer
« Reply #11 on: April 14, 2021, 11:37:55 AM »
Glad to hear it.
electricuted-smiley electricuted-smiley electricuted-smiley electricuted-smiley
military surplus MEK-016B generator
Started by OneWithWood on Alternative methods and solutions
Last post June 04, 2011, 07:56:28 PM
by OneWithWood
3 phase generator
Started by cubdriver55 on Sawmills and Milling
Last post October 30, 2010, 04:08:21 AM
by weisyboy
3 phase generator...Help needed
Started by Wisconsintimber on General Board
Last post November 10, 2016, 05:26:50 PM
by Kbeitz
Surplus Center ??
Started by beenthere on General Board
Last post February 16, 2009, 01:45:05 PM
by ErikC
