Removing Bark
Started by clintnelms, September 14, 2016, 10:28:10 AM
clintnelms
What's the easiest manual way to remove the bark from SYP? I've got a guy I work with that's planning on cutting down 3 SYP trees as soon as it cools down and he said he'd give me the logs. It'll take me a good while to saw that many logs. So I've read that the bark needs to be removed so they'll last longer. I've used a long tamping bar before that has a sharp end on it, but I'm wore out before one log using that heavy bar. Looking for some easier methods.
As late in the year as it is, I would stack them off of the ground and not worry about the bark.  You will be good at least through the Fall & Winter.
Texas Ranger
Stand em out like MM says, and in a while you will hear ol Maw Nature working on that bark.
ozarkgem
Maybe less work to just saw them than to remove the bark.
clintnelms
Quote from: ozarkgem on September 14, 2016, 08:32:42 PM
I don't plan on them sitting any longer than I have to. I just don't have a lot of time but on the weekends.
Satamax
I don't know if there is any big samill near you. But, if you're getting the logs from your friend's land. May be it would be worth sidetraking to a big mill with a debarker  ;D
customsawyer
Get them up off the ground and you will be fine. Even if it is a few months until you get them sawed. If your friend isn't taking them down until it cools down that will be even better as it will take longer for the blue stain to set in.
www.thecustomsawyer.com
clintnelms
Sounds good. Thanks for all the comments.
LittleJohn
Depends how much you have to move them, if you plan to move a bunch leave bark on until its sitting on the mill.
...like MM state, get logs off the ground.  That is always a good thing in my book, as I almost never saw "fresh/green" logs
ppine
Traditionally people use a spoke shave or a spud.
I have done it all day everyday for a few weeks and it is pure drudgery. For a couple of trees it is no big deal.
There is a debarking attachment that can be put on a chainsaw.
Forester
Czech_Made
