WoodMizer LT15 Help
Started by Mark M, May 20, 2003, 04:20:43 AM
Fla._Deadheader
Nobody said anything about winnin a contest?? Ya dint stipulate a perfessiunal performance??  :D
Mark M
What is dat Kevin, some kind of slot machine? :D
Kevin
Mark,
You need a steel shaft for the crank assembly and two pulleys at the bottom on the carriage.
You crank the handle one way and it picks up the rope and pulls the head along the bed.
To bring the head back I disengage the crank by pulling back on it and the spool turns free and is independent from the handle.
Mark M
Yep - I have all the parts, what I can't figure out is there must be a bushing missing or something because the crank should have the same ID as the pully bearings since in rides on the same shaft but it is a lot larger.
jimbo
Mark if your just using for travel  dont warre about it . use the barings on a 5/8 bolt whear you can keep the handle engage  in the pully  that all it takes for that    Good luck
             jimbo
Kevin
It's a nice feature having it disengage so it isn't spinning around when you pull the carriage back.
