What’s the difference?
Started by Tacotodd, July 01, 2020, 10:56:58 AM
Tacotodd
I'm contemplating getting a small bandsaw mill for my family and to use for other people that I really like and care about.
My question, besides fuel, oil, and price: what is the ultimate reason for a bandsaw mill over a chainsaw mill?
I ask because I don't know, so please, enlighten me!!
Trying harder everyday.
YellowHammer
Without being too tongue in cheek, the difference in any bandsaw mill and a chainsaw mill is that a bandsaw mill is fun and and enjoyable, while a chainsaw mill is a full contact sport.  Put on your chaps, your face screen, your eye protection, ear protection and get ready to rumble.
A bandsaw mill, even the cheapest, would cut faster, with less physical effort, less kerf waste, and produce many multiples of the amount of boards over a CSM.
A CSM can be set up to cut pretty much anything, even extremely large logs, which is one of its main advantages, is extremely portable, but cuts relatively slowly, and will bathe the operator in sawdust, noise, and vibration.  Plus the fact that if you don't spend money on a high end chainsaw, it will melt from the prolonged full throttle required.  I started with a chainsaw mill, I remember those days fondly.   It was like a rite of passage, and I would push that thing until lunchtime, or until I thought I was going to throw up.  So I called it the "Puker" and still have it tucked up in the barn loft and won't sell it for nostalgia reasons but would never use it again.
There are folks on the Forum who use a CSM routinely so take my advice with a grain of salt.
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
Haleiwa
I'd say it's kind of like the difference between a garden tiller and a tractor with a disc.  Both will eventually get similar results, but at the end of the day the tractor driver will be in a lot better shape and have a lot more acres done. Chainsaws are designed to cut across the grain.  No amount of modification will change that.
Socialism is people pretending to work while the government pretends to pay them.  Mike Huckabee
Southside
Not being a wise guy, but probably 10 minutes per cut vs 15 seconds in some cases.
Resonator
The bandsaw mill is faster, and more versatile (squaring, edging, resawing, etc.). Plus you'll cut more boards out of a log with a thin kerf blade.
Walnut Beast
Quote from: YellowHammer on July 01, 2020, 11:41:33 AM
Ok. Would you guys that have a dedicated wide slabber mill agree with this. ( not a regular chain saw mill)
Walnut Beast
Quote from: Walnut Beast on July 01, 2020, 02:00:16 PM
I think YellowHammer is pretty much right. But I guess what I'm trying to say is the guys that have a Dedicated Wide Slabber are you happy with the results. Sharpening the chain constantly, the extra time cutting and everything else YellowHammer mentioned. At the end of the day are you happy with the results and would you buy another one
Nebraska
When I was a year or so younger than you, I did some CSM. I found it something less than enjoyable. It wasn't a need thing as it was a progression of the disease had to try it..... I chewed up a pretty new 90 cc saw. (Ran lean on a fuel line crack).  It scratched  the itch and ecucated me ....I  saved some money and bought....My simple little manual mill is light years easier, cuts way nIcer, and is so much  easier on me. The only reasons I see for CSM are remote builds on a shoestring budget, dedicated wide slabbing machines as mentioned previously, or you just because have to saw some wood and space to put stuff is an issue. By the time you get a quality CSM setup, you are probably halfway too an entry level band mill.. I would buy a band mill.
Quote from: Walnut Beast on July 01, 2020, 02:00:16 PMOk. Would you guys that have a dedicated wide slabber mill agree with this. ( not a regular chain saw mill)
A dedicated slabbing mill is fairly hard work, but you are standing up away from the sawdust and exhaust fumes, have a quieter 4 stroke motor, and basically just need to lean on the mill to keep it feeding. It's no where near as hard on the body as running a chainsaw mill. It is slower than a band or swing mill, but you use it for situations where it's needed. Not many portable (or affordable) mills can slab 4 or 5 ft dia logs.
It's not so much about which mill is "best", it's which mill suits YOUR needs better.
Walnut Beast
Thanks Ianab. Nice feedback on a Slabber
terrifictimbersllc
.....in terms of WORK to make boards.......
Bandsawing is like getting a GED or maybe a BS degree.
Chainsaw milling is like getting a PhD.....by kicking yourself in the behind.... (heard someone else say this)
Above was modified for clarity..... :)
Sorry no offense intended for those enthusiastic about CSM as I still can remember being. :)
Tacotodd
Gentlemen, thank you for the information!
DJ, I would think that assessment would be backwards, but again, just asking for personal information.
Good day and have fun in whatever you do!!!!!
SawyerTed
CSM 1 hour of work and you have a couple of slabs made if all goes right.
Bandsaw mill in an hour you can have 200 board feet of usable lumber or a dozen 8/4 live edge pieces.
terrifictimbersllc
Quote from: Tacotodd on July 06, 2020, 09:40:08 AM
I clarified it a bit  thanks ;)
Tacotodd
I've only done a little research on them but the least expensive one seems to be out my VERY strained budget, so I will have to scratch and strain it for a while to be able to get one.
I guess that a sawmill of any kind is realistically out until the lottery that I don't play (won't waste money on) comes my way.
Thanks folks.
DJ, I'm not that flexible!😊
terrifictimbersllc
Quote from: Tacotodd on July 06, 2020, 10:46:14 AMDJ, I'm not that flexible!😊
The less flexible you are the more a bandsaw, and one with hydraulics, makes sense.
Tacotodd
I was referring to my own physical body, but I appreciate your input
Budget still can't handle that expense.
Tacotodd
DJ, my knees can't even momentarily bend NEAR that far, at least not since 2nd grade. haha
