Help with a dig pattern.
Started by Jeff, June 04, 2023, 04:42:25 PM
Nebraska
Needs a few Bluegills now.   ffsmiley
doc henderson
Looks like you did a great job on the solar array.  Is that the recommended angle at your location?   :usa:
Quote from: doc henderson on April 28, 2024, 04:24:39 PMLooks like you did a great job on the solar array.  Is that the recommended angle at your location?  :usa:
Yes, for this time of year at due south. I can adjust the angle steeper as the year progresses. We used an App. :)
I looked at the hostas, they are up and doing good.
The wood chucks are doing good too.  smiley_thumbsdown  I found 4 places that they are active. I am going to see if I can slow down the active part.  :wacky:
Need some red foxes around. Mine here cleaned up on the ground hogs I had for 2 years. Even saw the fox around yesterday on patrol. :)
When I had chickens, I had foxes. Maybe I need to get chickens again.  :wacky:
We always had wood chucks here.
Have not found anything to clean them out.
They seem to be in cycles like rabbits. They will get plentiful for a year or two, then the foxes clean house. We've always had groundhogs to, the foxes seem to know it's time to clean them out every so often.  ffcheesy I have not seen one around here since last spring. I did see one 2 miles up the road yesterday, the neighbor there said he saw a fox around to. So groundhog days are numbered. ffcheesy
Corley5
We have resident foxes and rarely see ground hogs. 30 years ago there were lots of them around and foxes were seldom seen. Now we see foxes. We had some ground hogs move in a couple years ago or so. A buddy saw one with a little one day and thought I should get right after them and kill them before they undermined my farm buildings and multiplied more. I'd seen them around too. The foxes took care of the population. I'm still seeing foxes and haven't seen a ground hog since.
Resonator
My sister and brother-in-law have Hosta's growing in their back yard. He likes to refer to them by the full Latin name: "Hosta La Vistas". :thumbsup:
Quote from: Resonator on April 29, 2024, 09:28:38 AMMy sister and brother-in-law have Hosta's growing in their back yard. He likes to refer to them by the full Latin name: "Hosta La Vistas". :thumbsup:
Also a white fir (Abies concolor) with that name
https://www.gardenia.net/plant/abies-concolor-hosta-la-vista
Built it, and they will come. All of them.
Not so far this year. Still deciding if I want to hunt. I have 10 points. I could get a tag anytime I choose. Probably since we are having a pigroast, I won't hunt. That takes dedication of time
doc henderson
Will you hunt in your own land, or are those deer considered residents.  Should be easier if you know what is there, but if you begin to recognize then as individuals...  I will be sad to miss the pig roast, but it is my wife's birth month as she is about to become 60.  I think I will do well to concentrate on that.  We are going to a Morgan Wallen concert in KC she has planned for 6 months.  She enjoys going to FF events, but now I need to do the same for her.  birth month.   :wacky: ffsmiley
YellowHammer
How close is the nearest other water source to this?  It sure is getting some wildlife traffic.  Pretty cool!
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
Once we get into summer, probably less than a quarter mile to the carlton Marsh leading to the st. Marys river across the road, in dry weather.
 Really no shortage of water, just small water areas that get rare.
This will give you an idea of my surroundings. Pretty wild.
Doc, hunting on my propertyis always my goal, but I'll hunt anywhere there's game if given the opportunity.
Beautiful day in da eastern u.p.yesterday.
I agree.  Beautiful day in a beautiful happy place.  ffcool
That pond sure does look nice.
