Faster UP for older woodmizers
Started by pineywoods, August 23, 2007, 07:34:22 PM
Dan_Shade
I looked into upgrading my electrical/hydraulic system to match a super a few years ago.
the alternator and battery are bigger to supply the needed power.
lots of dull bands and chains
pineywoods
The single spring mod helps a bunch, but the 2 spring version is even better. More lift and it's more consistent across the full range. Another thing I noticed is it's a bunch easier to stop on the mark when dropping down...
Chuck White
I'll most likely end up adding another spring.
Probably just go buy 2, then they'll be of the same tension.
Thanks again Piney
VictorH
I was looking at doing this mod to my mill as well.  I have a 95 and it has an external alternator.  I have looked at springs at the local ACE and they have several sizes and are rated for different weights/loads.  I realize you both used springs from your 'piles' but if you could tell me the length and diameter of the springs you guys used I could compare that with what's on the shelf.  I'm also interested in people's opinions on which safety measure would be better.  A cable run through the spring or a piece of PVC around the spring?
Victor
Chuck White
Victor, I just used a regular overhead garage door spring.
In the 3rd pic, the spring is double it's relaxed length.
I think that the cable ran down through the length of the spring is just as good as any other safety device.
The primary thing you would normally be concerned with, is pieces of the spring going flying in the event it breaks!
sumday
Victor, you might try calling the local garage door company/companies and see if they have used springs from doors they have replaced. Might get them free or at least cheaper than new from Ace.
pineywoods
The 2 springs I used came off an 8 ft wood overhead door. The door was replaced with a metal one, I liberated all the hardware including the defunct electric door opener...
ladylake
No pics but i mounted a torsion garage spring on mine which was fairly easy.   Steve
trapper
Good idea with the spring.  On my lt30 where your bracket goes in the top of the post is where my water bottle mounts.  Where does your water bottle mount?
Chuck White
trapper; My water bottle and gas tank both mount on the (black) shelf that has the wrenches laying on it, right near the top of the sawdust chute in the 3rd pic!
trapper
My shelf is only big enough for the gas tank. Need to find a place for the water bottle.
Maybe where I dont have to  lift so high to fill it and maybe a smaller water bottle.
jmouton
I  got a question  for ya,   I have a older lt25 manual  ,does it help  with the manual up and down ,cuz   I  did it to my mill  and it didnt help  , think the garage door spring isnt heavy enough , how thick is the coil stock  of the spring  and how long  is it relaxed  , it would be nice  if the cranking up was better
        thanks alot          jim
lt-40 wide ,,bobcat,sterling tandem flatbed log truck,10 ton trailer, stihl 075,041,029,066,and a 2017 f-350,oh and an edger
Chuck White
The spring helps to lift the sawhead!
The spring takes a lot of the strain off of the up/dn motor and both up and down now opperate more smoothly!
Chuck White
I just went out and took measurements on the spring I put on my mill!
Relaxed spring length:  31 inches
Extended spring length:65 inches
Diameter of the spring: 1¾inches
Diameter of the spring material: 1/8 inch
Sorry it took so long to reply.
Ole school bus drivers walk slow.   smiley_old_guy
Chuck White
pineywoods
This simple upgrade has been in place for quite some time and has served me well. After some problems with the up/down motor, I started thinking about the possibility of a larger faster motor. The original is sandwiched between the brake band and head support column, so there's not enough room for a much larger motor. What about the starter motor off the lawnmower? About the same size, but 4 poles instead of 2 so should be twice the torque.. worth a try. Dis-assembled the starter, lifted 2 brush leads from frame ground and routed them out through a hole drilled in the end plate. The slots for the mounting bolts had to be lengthened a bit, and I used a slightly larger v-belt pulley cause that's what I had. Otherwise, pretty much a bolt on operation. Hooked the power leads to the wires from the old motor and hit the up/down switch...WWHHHOOOO BOY, this thing is FAST. About 3 times the speed of the original motor. Looks like factory
Bandmill Bandit
Hey Piney woods
That a real great idea. What model of starter motor did you use? Could you post the specs for us?
pineywoods
Quote from: Bandmill Bandit on August 07, 2016, 11:38:49 AM
Hey Piney woods
Junk yard special. It came off a 10 hp tecumseh on a junked riding mower..No markings of any kind..One drawback, which I kinda figured on, is the 15 amp alternator under the flywheel won't quite keep up, so I hook up a battery charger at night..I need to install an automotive belt driven alternator.. another project  ::)
Kbeitz
Almost all 10 hp tecumseh starters are the same...
Love machine shop work
and Wood work shop work
And now a saw mill work
