Author Topic: Got a bigger shovel  (Read 4795 times)
Offline ljohnsaw
Re: Got a bigger shovel
« Reply #20 on: July 27, 2016, 07:53:09 PM »
John
I don't think it would be easy to add a valve to the block. I think a selector valve would have to be used that is why I am thinking a miniature electric pump. I also see that many small hoes have a manually operated thumb that may be a option. :)
If you go the manual route, make the geometry, and holes, so that you can swap out the link with a ram down the road.  While a fixed will work, the finesse you have with a hydraulic ram is fantastic.
John Sawicky
SkyTrak 9038, Ford 545D FEL, Davis Little Monster backhoe, Case 16+4 Trencher, Home Built 42" capacity/32" cut Bandmill up to 54' long - using it all to build a timber frame cabin.
Offline gspren
« Reply #21 on: July 28, 2016, 01:45:40 PM »
   Are you going to the pig roast? I would give you a nice little hyd cyl, about 2x6.
Offline 21incher
« Reply #22 on: July 28, 2016, 05:03:23 PM »
I wish that I was, but no. I am seriously trying to make plans now to go next year so I can meet some of the great members of the Forestry Forum. Thanks for the offer, but for now I may just make a manual thumb to see how  usefull one is on a machine this small.  thanks again.  :)
Hudson HFE-21 on a custom trailer, Deere 4100, Kubota BX 2360, Echo CS590 & CS310, home built wood splitter, home built log arch, and a logrite cant hook.
Offline Ox
  • Trying to learn/remember something new every day.
« Reply #23 on: July 30, 2016, 09:39:31 AM »
7/30/2016 - Happy birthday, 21incher
Offline 21incher
« Reply #24 on: July 30, 2016, 12:32:53 PM »
Thank you.
Offline lowpolyjoe
  • Hey
    • JeRM Software Page... Hobby projects
« Reply #25 on: July 31, 2016, 10:45:12 AM »
Great Videos!
Lots of great tips in your commentary.  Thanks for sharing.
thumbup
I got a new snow shovel !
Started by DR_Buck on General Board
Last post February 25, 2010, 07:15:54 AM
by submarinesailor
Shovel logging
Started by bbdale10 on Forestry and Logging
Last post June 06, 2019, 08:32:03 AM
by Skeans1
question
Shovel logging
Started by WvLogHauler on Forestry and Logging
Last post June 09, 2010, 02:04:14 PM
by BaldBob
Shovel logging
Started by Frickman on Forestry and Logging
Last post August 07, 2007, 08:34:43 PM
by Tillaway
