Predator Swap on LT 35
Started by ajkoontz, November 13, 2020, 08:46:02 AM
ajkoontz
I think we're going to swap out the engine on an early 90's Woodmizer LT 35 over Thanksgiving weekend. It currently has the opposed twin Briggs engine that came from Woodmizer. Seems pretty straightforward, but I figure at least a few on here have done this and wanted to check on here if anyone has any advice. One thing I need to figure out- what size pulley will I need to get?
Does anyone know if the pulley on the Briggs shaft will fit the Predator, or I guess what I really need to know is the shaft size of the Predator engine and the correct outer diameter?
Other than that it seems like build a bracket to mount up new holes, a few new hoses, some longer wires, and maybe some work on the throttle cable. Is that about all there is to it or is there anything I'm missing?
Thanks in advance
btulloh
There are manuals for those predators that have all the dimensions.  Usually linked from the site they're being sold.
HM126
John S
I did not know that the LT 35 was available that long ago.
2018 LT40HDG38 Wide
mike_belben
Vtwin predator has a 1inch shaft. So does the electic start 1 cyl.. 13hp i think? You didnt mention what model.
Praise The Lord
SawyerTed
The website has the shaft sizes for those motors.
chet
A quick online search will give you the owners manual, that will answer your mounting questions. As with most factory settings on new engines these days the carbs come set really lean. Again a quick online search will guide you through the remedy.
47sawdust
perhaps an LT30....too early for LT35
Mick
ajkoontz
