You can find the bits in 1". The other sizes are more common for clearance when assembling with 1" bolts. I'd only buy the bits you need instead of a set.
I pick the 1700 lb. mower up, and set it on the big flat tail end
Yes. I like sharp blades, but won't get under a mower, so might as well do it so I don't even have to bend over. That marine lifting ring will lift 5,500 pounds, but even with that, I'm not getting under anything.
The gold standard for mag drills and cutters isHougen Manufacturing. Used by steel fabricators.
Started by Preserved on Timber Framing/Log construction
Started by thedeeredude on General Woodworking
Started by Sawyerfortyish on Sawmills and Milling
Started by j napier on Sawmills and Milling
