Author Topic: LT30HDG24 trailer ball height question  (Read 466 times)
Offline Jim_Rogers
  • Keep your chisels sharp.
    • jrsawmill.com
« on: October 21, 2019, 09:18:55 AM »
I'm about to get another pick up truck, and I need to fit the trailer hitch with a new ball. I need to understand what height the ball should be off the ground for the correct transporting of the mill down the road.
I measured my old off road SUV that I used to use to pull my mill as 14" or so.
The newer truck would most likely sit higher but I can buy a drop down receiver bar for the ball.
Does anyone have any advice on this? Other than call Woodmizer.
Jim Rogers
Offline terrifictimbersllc
    • Terrific Timbers LLC
Re: LT30HDG24 trailer ball height question
« Reply #1 on: October 21, 2019, 09:24:41 AM »
Can you measure it from your mill?  Height of hitch with mill rail parallel to ground?
Offline ljohnsaw
« Reply #2 on: October 21, 2019, 09:27:11 AM »
I just set any trailer on flat ground and level it.  Then measure up from the ground to the top of the hitch (where the ball sits).  Now, measure from the ground to the top of the receiver on the truck.  The ball is going to raise up from the hitch about 3 or 4".  Then figure out from there.  Better to sit and inch or two high then an inch low.
John Sawicky
SkyTrak 9038, Ford 545D FEL, Davis Little Monster backhoe, Case 16+4 Trencher, Home Built 42" capacity/32" cut Bandmill up to 54' long - using it all to build a timber frame cabin.
Offline Jim_Rogers
    • jrsawmill.com
« Reply #3 on: October 21, 2019, 09:33:37 AM »
I suppose so, I'll see what it looks like.
Jim Rogers
Offline GAB
« Reply #4 on: October 21, 2019, 09:47:09 AM »
Don't forget that what you load in the back of the truck may also affect the height.
You might want to consider an adjustable hitch height unit.
GAB
Online doc henderson
« Reply #5 on: October 21, 2019, 09:47:26 AM »
stiff suspension will drop less.  what type truck?  I have 4 diff receivers with balls for my diff. trailers.  could ask about tongue weight, wood miser may know, then do the measurement with that amount of weight/people standing on your bumper.  My one ton is a lot higher than my old heavy half.  I agree you want the mill/trailer parallel to the ground.
Offline Jim_Rogers
    • jrsawmill.com
« Reply #6 on: October 21, 2019, 10:37:10 AM »
 what type truck?
GMC 4 wheel drive, not sure the model right yet, I'll be test driving it later today.
Quote
I believe, from memory, about 80 lbs but I could be wrong.
Jim Rogers
« Reply #7 on: October 21, 2019, 12:18:47 PM »
I overestimated the drop once and tractor supply let me return the receiver and get a diff one.  is it lifted?  pics later?   8) :D
Ball hitch for log arch trailer
Started by Stevenjohn21 on Urban and Community Forestry
Last post July 17, 2022, 11:20:38 AM
by Al_Smith
Wire Brushing My Ball and Other Trailer Maintenance
Started by SawyerTed on General Board
Last post September 21, 2022, 06:11:57 PM
by scsmith42
Log trailer arch height
Started by fishfighter on Sawmills and Milling
Last post December 07, 2016, 11:37:53 AM
by Upper
Max height of trailer tail lights?
Started by Corley5 on General Board
Last post October 27, 2007, 10:48:15 PM
by Quartlow
