oil
Started by peterob, January 18, 2014, 09:05:44 PM
peterob
just a question what is everyone running for oil i have a 25hp  kohler  on a lt28  thanks peter
dgdrls
I run Full synthetic Castrol  in My Kohler 27 & Napa Filters
Check the Kohler site for weight requirement and spec/rating if you don't have your book(s)
DGDrls
Chuck White
I use 15W40!
Seems to work well, I also shut down when the weather starts to turn cold and start up again in the Spring!
bandmiller2
Once A new engine is broken in on dino oil theirs no reason not to go synthetic, on this sized engine cost is a little factor. Aircooled engines run hot and the extra protection, not to mention cold starts, makes it worthwile. A little 2cyc. synthetic mix added to the gas will help the valves and the engine top end. Good engine management will extend the life of your engine. Frank C.
Bill Gaiche
10w-30 wal mart synthetic. Use this in all my engines except diesels. bg
Dewey
I run Mobil One 10-30 Napa Filter I have over 6500 hrs on this motor
