Thanks for your reply,Joe,that's a lot of good info.Good on you for those generous overhangs,Nothing like these will preserve the wooden house better."Popple",as you say(i've heard that before,but it can be confusing as it can apply to different poplar depending on the region,like Tulip p. in the S.Eastern US,and Poplars are a huge family....All's i have access to in AK is the Balsam p.,Aspen(not of any size in my area,alas,and of course Birch(another poplar relative,technically).The cottonwood i used for posts and beams in my house i've treated in a weird way:As an experiment,following this obscure,ancient Eastern European practice,i left them in a pile,bark-on,for a year after harvesting(in winter).They're supposed to undergo a certain chemical change,a conversion of starch to sugar and so on,to become more suitable for further seasoning.I'm afraid to report that it didn't do them many favors structurally.Especially that (contrasting,here)heartwood has suffered,becoming of a weird/granular/some kind of decomposition texture...To the extent that any thought of cutting a solid tenon,or using the inside portion of a boxed-heart timber in many other ways became unthinkable.Lumber cut from Balsam p. is said to harden very significantly in a year or two,and to continue to go that way(to the point where after a few years the boards would have to be drilled for nailing through them).Very thin,1x-ish lumber flat-sawn from Balsam can be very unruly and require careful stickering,but eventually settles down and remains fairly civilized,even suitable for panelling as in wainscot and such applications..."Traditionally"/historically,poplars were used for water or food-related applications,wash troughs,butter-churns,and other such uses being very alkaline,base in their chemical nature,"sweet" as they used to say,non-acidic...
Yes it seems to do fine getting wet, if it can dry immediately.
Kizhi? That is some fascinating architecture. I have a coffee table picture book by Opalovnikov, the gentleman that did a lot of the restoration work there. Kizhi
Started by maineshops on Ask The Forester
Started by L. Wakefield on Forestry and Logging
Started by donbickley on Ask The Forester
