Saw wobble. Need some expertise.
Started by francismilker, January 09, 2013, 10:47:48 PM
cotton picker spindle cleaner,I guess I would have to special order that.  :D  Much cheaper than the lube that I use. Does sound good.  If I did order a 5 gallon bucket,the plastic bucket would rot out before I used it all up.  ;D
Yeah, that is the problem with the 5 gallon bucket.
dboyt
As long as we're on the subject, a lot of mills, including mine, only drip lubricant to the top of the band.  Does enough lubricant get to the bottom of the blade, or would a system that applies lube to both sides be more effective?
Norwood MX34 Pro portable sawmill, 8N Ford, Lewis Winch
